quote for thermostat changee
dares_uk Feb 15, 2010
  1. dares_uk
    dares_uk Member
    169
    had a quote just now for 3113 + vat for
    supplying and changing the thermostat on my s3,
    is that good or bad?
  2. zeeeebo
    zeeeebo Lifes one big laugh
    416
    i would hope you meant 113! i got the thermostat for a 5er and took me an hour to fit! its very very easy! there is a guide on the tt forum which helped alot!
  3. finesse
    finesse Active Member
    2,805
  4. Matt82
    Matt82 Active Member
    2,365
    bargain.
    you were joking right?
    that would work out at about £200/hour labour
  5. tankie2ndrtr
    tankie2ndrtr Member
    211
    I had mine changed at a VAG specialists for £70 with complete coolant change... (colchester, Essex)
    Thats getting close to Mr Audi Prices....
  6. rossbrownlee
    rossbrownlee Ross_S4
    719
    £113 is probably about right for audi dealer prices. However, no doubt you could get this done cheaper in a local garage, also you should consider doing it yourself. it is a bit of a ballache to do (no matter how many people on here who will post up saying yeah it is a 30 minute job...) but there are good guides available online and it is do-able with a bit of care and a fair bit of effort.
  7. golf
    golf ***** rent boy VCDS Map User
    1,556
    I would not pay more than £40 out of principle, although it's a bit of a pain in the arse to do, it's fairly simple if you have the right tools.
  8. sp84
    sp84 Member
    Audi wanted £200 labour from me to change the Thermostat not including part.
  9. Matt82
    2,365
    on a 20vt? i doubt theyd even charge that on an S4, and thats a cambelt off job. were they ROFLing when they gave you that quote?
  10. sp84
    sp84 Member
    I hope he was I asked him a couple of times to make sure
  11. Matt82
    2,365
    :( thats so bad that you guys get ripped off so badly. with S4s they love paying through the nose for trivial things and people end up being mugged off due to an illusion that its some form of exotica
    in this case is a 20vt, one of the most common engines going
  12. dares_uk
    dares_uk Member
    169
    dont fancy doing it myself,
    and yes i did mean £113 + vat, was quoted for an hour and a half labour.
    at a specialist, not a dealer.
    will shop around me thinks, :)
  13. Matt82
    2,365
    itll take them about 20 minutes so theyre mugging you off
  14. jonny87
    jonny87 Active Member
    1,094
    dude fair enough if you dont want to do it yourself, but this job is seriously easy, a little bit fiddly but easy, if you got a mate who is handy with the spanners slip him £40 and im sure he wouldnt mind doing it for you following one of the guides on here you couldnt go wrong
    if not though a garage should not charge you more than an hours labour and no more than £20-30 in parts (my stat plus 2 bottles of coolant cost me £17)
  15. 1animal1
    9,976
    it certainly isn't 'very very easy' Zeeeebo.....dunno if the S3 is tighter to get to than your A3 but you run the risk of turning an hour job into a several hour job extremely easily..... i paid my neighbour with a crate of lager
  16. zeeeebo
    416
    yer the a3 was very fiddley and took ages for the bottom screw to undo and put back in but i had a bendy extension arm which helped soooooo much! as soon as the 2 screws are done its very easy! im not familar with an s3 bay but i presume its roughly the same!
  17. Barks
    Barks Member
    337
    Did my a few weeks ago, very easy, it is fiddly getting the one bolt off, I just used a 1/4 drive extension and a 1/4 universal joint, Make sure you get a new dip stick tube as well as I broke mine, Therostat, DIp stick tube and fluid all available from GSF
  18. Matt82
    2,365
    when ive done them before i renewed the o ring too.
  19. 1animal1
    9,976
    Good call Matt, goes without saying but easy for someone to miss.....
    zeeeebo, its a different lay out at the front im sure as i think the S3 has more obstructive pipework, but same obstruction with alternator making your life hell IIRC
  20. Matt82
    2,365
    those o rings are used on for a few cooling things on the golfs. basically after a few years they go brittle and stay flat, basically they dont seal properly.
    on old cars like that, id recommend you put new seals in wherever you have to take one out
    on cars where its hard to get to these water connections, youd be gutted if you do all the work and then once you start it up it leaks from the joint
  21. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Remove aux belt, remove top alternator bolt, slacken bottom one. Pry with pry bar, alternator falls towards front of car. Unbolt hard plastic pipe from block face (2 x 10mm bolts), pull thermo out, replace, repeat process in reverse.
    Easy peasy.
  22. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,252
    354
    Hi guys
    Just did the 49C trick thing on the climate control unit
    The 49C reads 78ºC at standstill (car has warmed up), when driving it varied, up to 80 but with a minimum of 73ºC. The gauge in the dash varies as well but between 80 and 88ºC.
    I am assuming that this is bad. And probably needs a new thermostat?
    Alex
    EDIT: Oh yeah, and my mpg has dropped from ~29.5 to 26.5 mpg
  23. Welly
    10,696
    127
    Yep, thermo most likely. Especially with the MPG drop...
  24. Matt82
    2,365
    welly, i expect the stat housing is pretty accessible right now on your block ;)
  25. Welly
    10,696
    127
    Whatever makes you say that.....? lol
    Yes, swapping my thermo from one block to the other might of been quite easy.... :)
  26. zeeeebo
    416
    yer i had a new dipstick holder before i started as my one was very very brittle
  27. Matt82
    2,365
    question for ya... had you ever tackled anything quite like that before hand?
  28. Welly
    10,696
    127
    Nope, new for me....
    Best way to learn is crack on though! :)
  29. Matt82
    2,365
    more thumbs up for you then. reward yourself with a beer :D
  30. Welly
    10,696
    127
    LOL, I can't NOW. Providing IT Support whilst p*ssed isn't too easy.... lol.
    I wouldn't be popular with the boss....
  31. Matt82
    2,365
    offer him a beer too. be a good sport.
    beer'd up mechanics is one of my best hobbies tho
  32. Welly
    10,696
    127
    LOL, I only tried that once and it was NOT pretty! I ended up falling over something, onto the car and broke my nose.
    Never again.
  33. jonny87
    1,094
    fpmsl
    my mate is always drinking whilst working on his grass track car, more evident when hes welding in new panels etc
    welding starts off sweet as a nut and ends up looking like pigeon s*** lol
    and he usually has a burnt hand where he loses concentration and tries welding his hand to the car lol
  34. Alex C
    3,252
    354
    WOW! Just quoted £190 labour for changing the thermostat on my S3 from the dealer, that doesnt included parts. They said thats 2.5 hours work and then they said thats subject to stripping time so it might go up if they find that there are some bolts that are hard to undo!!!
  35. Matt82
    2,365
    bring it round mind and ill do it for £50
  36. Welly
    10,696
    127
    Hmmmm. I guess buy that they mean in case 1 of the 2 (yes - just 2) 10mm, non torqued bolts they would have to undo to get the thermo out is hard.
    What a f**kin joke!! :mad:
  37. Welly
    10,696
    127
    Too bloody right, I'd help out if you were closer mate!
  38. Alex C
    3,252
    354
    lol, I think even if I drove upto you and payed you £50 it would still be cheaper! Where abouts are you Matt
  39. Matt82
    2,365
    essex, it would be mad... just get some spanners and do it. its an old car anyway, it doesnt matter who works on it.
    the bolts want to be 10nm, thats about the only technical part.
  40. Matt82
    2,365
    its like you audi drivers are just despirate to pay money to have trivial things done on these cars, that climate and mindset is what makes people rip you off so badly.
    time to MTFU!!!!
