Quote for a cambelt?
- Apr 25, 2005
  1. Guest
    I,ve been quoted £300 + vat inclusive parts & manual by a specialist non-dealer, is this reasonable?
    Also if I were to get the parts from GSF do I need the timing belt tensioner damper on top of the belt and tensioner? All this for a 1.8se '96 P reg A4 Avant 77 000miles on the clock.
  2. IanL-S3
    IanL-S3 Member
    923
    i think some people have paid upward of 800, but i've not had it done myself-so i'd wait for them to reply! but its also been said that you should change the water pump at the same time too, as the cost of the part is quite low and the labour charge shouldnt be much if any more.
  3. AndyMac
    9,832
    45
    £300 is about right and you do need the damper. I'd definately change the water pump at the same time as well as they have been known to seize at around 100k miles and it's only another £35.
  4. Kevint
    Kevint Active Member
    1,182
    I've got a 1.8T.
    Audi quoted £350 all in.
    Local independant (who I know well) wants £90 for labour + parts.
    Kev.
  5. I was quoted £350 parts and labour from Highland Audi in Inverness to change the cambelt on my 98 S4, which I thought was very reasonable.
  6. Broken Byzan
    13,237
    465
    The later 1.8's dont have the water pump driven by the cam belt do they??
  7. AndyMac
    9,832
    45
    Cononcars, that's unbelievable! Southampton Audi charged me £700 +VAT on my V6 and it's not even an S4.
  8. Kevint
    1,182
    [ QUOTE ]
    [/ QUOTE ]
    Not according to my local dealership when I asked them.
    Kev.
  9. imported_Yaseen
    imported_Yaseen Guest
    early 1.8 a4`s don`t have the timing belt and water pump linked.
    Depending on where in country you are 300 will be ok.
    I paid a specialist in leeds £250 for timing belts/tensioner and all other belts last year.
  10. imported_Yaseen
    [ QUOTE ]
    I've got a 1.8T.
    Kev.
    [/ QUOTE ]
    Thats damn cheap it- if they do everything for £90 post name on here as it will be worth the trip to many! Reason it costs a lot is that bumper etc all has to come off- fair bit of work.
  11. I paid £350 in Jan for the belt and water pump for my 2.8 by an Audi specialist in Dorset.
    Don't pay anymore than £400.
  12. Kevint
    1,182
    [ QUOTE ]
    [ QUOTE ]
    I've got a 1.8T.
    Kev.
    [/ QUOTE ]
    [/ QUOTE ]
    Sorry, I'm having a **** day typing today!
    That is £90 for the labour, parts ontop, whatever they cost.
    /ubbthreads/images/graemlins/bang.gif
    Kev.
  13. Kevint
    1,182
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Kev.
    [/ QUOTE ]
    And to clarify this...
    The delaer told me that on my 99 A4 1.8T the water pump does not run off the cambelt.
    Kev.
  14. Broken Byzan
    13,237
    465
    Thats what i thought, my 98 has the waterpump running off a small belt taken from the PAS pump, I just had a look,lol
  15. mwarrey
    mwarrey Member
    280
    I would also recommend getting the Waterpump done at the same time as the timing belt. Should be little if any extra labour charge.
    Waterpump failed on my 1.8t recently, quite common on this engine at high miles. Part only costs about £40, but around 3-4 hours labour to fit.
  16. AndyC
    AndyC Moderator Staff Member Moderator
    719
    correct.
    the cam belt change really ought to have
    Belt!
    Tensioner pully
    Tensioner / damper
    worth of course doing the other parts at the same time.
    chaning the pump is a good idea as well as changing the stat... (OE Audi stat and seal are a good idea also)
    the aux belt tensioner is worth looking as, as is the runner for the air con, small pully right at the bottom
    not a huge job to do, but worth doing right!
    if your going to do a snub mount, now is also the time to do it as the carrier is off and its basically labour free at this point.
    Andy
    GDI
  17. Guest
    [ QUOTE ]
    Andy
    GDI
    [/ QUOTE ]
    Whats a snub mount? Sorry to ask but even though this is my third car in 5 years I dont know much about the mechanicals lol.
    What I know though is that there is no documentation of a cambelt change in the service book and I got the car 4 weeks ago with 77k miles on it, so I geuss it will be wise to get that sorted. So if there is anything that needs doing at this stage please let me know. Also the radiator is leaking a bit and do have to get a new one or is there a way to stop the leak? Thanks guys.
  18. AndyC
    719
    the snub mount is an engine stabiliser that resists the engine tilting back and forward when changing gear, accelerating or breaking... the better ones make things smoother and the gear change more accurate.
    not worth fixing a rad really, costs almost as much as a new one, the treatments you put in the water and good as a temp fix but thats all really.
    Andy
  19. Guest
    Cheers Andy.
