quick wheel spacer question
Irish EK Oct 22, 2012
  1. Irish EK
    Irish EK Member
    92
    Car: 2005 Audi A4 Saloon 2.0tdi s line saloon
    Alloys: 18x8j et 43
    Tyres: 235/ 40/ 18
    Will be lowered on 40mm / 30mm spring/ shock combo which will result (as its s line) in a 20mm / 10mm drop.
    What size wheel spacers to fill out the arches a bit? i dont really like wheels poking out.
    cheers :thumbsup:
  2. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,972
    726
    12mm spacers will give you ET35, which IMO is a nice even stance for our cars
  3. ASC
    ASC Member
    105
    20
    Wouldn't 8mm would make it ET35?
  4. ASC
    ASC Member
    105
    20
    I just recently fitted ET35 wheels to the car and it looks great.
  5. Macdoon
    1,972
    726
    Yea 8mil lol, had something else on my mind, i have just fitted ET35 rotors, looks great but needs lowering tho
  6. Macdoon
    1,972
    726
    235 40 18 ET35
  7. ASC
    ASC Member
    105
    20
    Nice, suits the car well with the colour. It will look sweet lowered. What set up you going for?
    This is H&R springs (30mm), 18x8 ET35 with 235/40/18. I probably could've gone ET30 to be really flush but the front might have looked a bit weird although I could run 5mm spacers on the rear only.
  8. Macdoon
    1,972
    726
    Not sure, doing loads of research, narrowed it down to either H&R or Eibach springs, not sure what drop to get, if I'm right 30mm springs will only give a 10mm drop over sline, so i'm guessing maybe 40mm H&R or maybe Eibach combo 50/40, decisions decisions lol
  9. DPM
    DPM Site Sponsor Site Sponsor
    4,917
    179
    I'd say 8mm/10mm front and 15mm rear.
    Damian @ DPM Performance
  10. Irish EK
    Irish EK Member
    92
    car looks great mate! so you went 8mm all round? do you find any vibrations with the spacers? do you find the front wheels poke a little bit or do they still tuck a bit under the arches? et35 on front looks spot on, might got for a 10mm or 12 mm spacer on the rear to fill it out a bit more to match the front :uhm:
    cheers for the pics lads, car looks great aswell! did you go 8mm spacers all round too? now that you have them fitted do you think the rear could do with another 2 or 4mm spacer?
    i was in the same position as you, i wanted to lower the car a touch but also keep it practical. it is my main form of transport and also use it to tow a motorbike trailer during the track / race season. the s line is 20mm lower than than the SE model so take 20 away from any quoted figures. there is also a 10mm difference between the front and rear of the s line suspension. i was going to go H&R 45/35 but after seeing pictures it is a bit too low on the front for me. what i have decided on is an AP suspension kit with dampers with a 40/30 drop. this will even out the front and rear height and lower it, keeping it practical but improving the looks. the rear will look the same as ASC with the front being 10mm lower.
    AP 40mm/30mm Lowering Springs & Shocks Suspension Kit A4 B7 Saloon 1.9TDi, 2.0T FSi, 2.0TDi FWD 01/05> - £313.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and
  11. DPM
    4,917
    179
    Could go for 8mm front and 12mm rear, both are available in hubcentric.
  12. ASC
    ASC Member
    105
    20
    No spacers on the car now. I did have 10mm spacers on with the original wheels (ET45) but the new wheels are ET35 so that cancelled out the spacers. I may still stick 5mm spacers on the rear only for flusher look. Front is fine I think.
  13. ASC
    ASC Member
    105
    20
  14. Irish EK
    Irish EK Member
    92
    i was originally going to go for a 40/30 drop but having looked at yours im thinking its low enough?! i still need my car to be practical. how do you find it? would you have gone lower in front in hindsight? and thanks to your pics i will def be going 8mm spacer up front (et35). what spacer do you think would be ideal to match the rear with front? cheers!
  15. ASC
    ASC Member
    105
    20
    No, I probably wouldn't go any lower on the front. The ride is a bit harder but not much. I might still put 5mm spacers on the rear which would take it to ET30, that will probably fill the arches so if you are ET43 at the moment then maybe 12mm spacers (depending on how low you go I spose)? DPM reckons you could even go 15mm.
