Quick Wheel Spacer Query.
Westy Jun 7, 2013
  1. Westy
    Westy Well-Known Member
    17,443
    1,103
    I was under the impression that the reason most people went with 10mm spacers on the front and 15mm spacers on the rear was because the front wheels were already 5mm wider then the rears as standard. Is this true?
    The reason I ask is because I used to have 10\15 spacers on my stock ET32 S3 wheels but I was just following the crowd. I sold these a while back to Dane and have only now started to look at getting some more for my stock ET32 TT wheels as they look pony tucked inside the arches.
    I was looking at getting 15\15 until I remembered that the fronts are supposedly 5mm wider already but If someone can confirm this as a myth I'll get 15\15 instead of 10\15.
    Cheers.
  2. Gops
    3,198
    666
    From what I know westicles, they are slightly wider than the rears, but not sure by how much. That's the info I read anyhow. 10/front 15rears seems to be the best compromise IMO.
  3. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    the bit of paper i have says that the track width of the S3 8L on the front is 1527mm and 1503mm at the rear making the front 24mm wider overall at the front. So 12mm per wheel
  4. Keefy
    Keefy Member
    139
    I ran 10/15 for a while with OEM RSTTs, but the fronts still appeared to be wider. I've since gone up to 10/20, which IMO looks a little better.
  5. Westy
    17,443
    1,103
    Interesting. What bit of paper do you have? Something from an alignment system?
  6. Alex C
    3,266
    360
  7. Westy
    17,443
    1,103
  8. Westy
    17,443
    1,103
    I'm now trying to work out the best measurements to get the ET32 wheels to sit as close to the arch as possible and to match front and back.
    I'll get the tape measure on it this weekend.
  9. Westy
    17,443
    1,103
    The RSTTs are ET35 AFAIK so my wheels stick out 3mm more each side already. 20mm might be a bit OTT.
    Any pics of your wheels?
  10. Alex C
    3,266
    360
    i have 8.5J ET25 wheels with 10/20 F/R spacers - admittedly they do stick out a wee bit
  11. Westy
    17,443
    1,103
    Are they genuine RSTTs? So your ET on the back is now ET5 lol
    If you could take a few pics for me when you get time id be very grateful. Thanks.
  12. Keefy
    Keefy Member
    139
    Mine are genuine RSTTs and they're ET33 - 20mm each side seems to sit just right. Can stick up some pics later :thumbsup:
  13. superkarl
    superkarl MAN OF STEEL
    9,467
    2,420
    Alex runs lms.
    You cant compare different width wheels either. Width affects the look as well as offset.
    Rstts are 8 inch wide afaik.
    Just get a dam tape measure out and measure from sidewall to the arch, simple as that.
  14. Westy
    17,443
    1,103
    Ill do that this weekend fool, said that above. If you had radius bolts with your kit id be buying them.
  15. Alex C
    3,266
    360
    yeah sorry, they are BBS LM 18" 8.5J ET25 with 10mm spacer on the front and a 20mm spacer on the rear
    To get the same poke on a 7.5J ET32 standard S3 Avus you'd be running 30/40mm F/R
  16. Westy
    17,443
    1,103
    Cheers matey.
    I wouldn't be going anywhere near that but i am looking at the possibility of 15/20mm just need to find somewhere that does a kit at a reasonable price.
  17. Alex C
    3,266
    360
    yep, the only reason i have spacer up front is for the brakes and then i was left with making the rears stick out so they looked similar to the front - hence the 20s on the rear
  18. Sidey
    Sidey Active Member
    284
    153
    43
    Im running 25mm adapters upfront and 30mm adapters in the rear on 42 offset wheels, ill be changing my rears soon to a 40mm adapter. The front sits way more out than the rears.
    Heres a pic to give you an idea...
    Alex C likes this.
  19. Westy
    17,443
    1,103
    That looks mint Sidey. My car is only lowered 35mm so I'm a bit worried that an excessively spaced 17" wheel might look odd.
  20. Jason.s
    Jason.s Active Member
    2,879
    348
    That does look pretty sexy
  21. <tuffty/>
    21,140
    3,828
    wheels are same width and offset, track or body width is makes the difference... 10mm on ET33 OEM RSTT's are perfect for the front but I have 15mm on the rear and personally reckon 20mm is required to 'fill the arches' in the same way the front is... if I get a chance I'll measure the track width front and rear and see if there is a difference... I suspect though its just the body width being wider at the back thats the issue
  22. kelk11
    kelk11 Member
    112
    not the greatest of pics but you get the idea, 15mm front and 20mm rear bought from here and been on 12 months with no issues http://www.jjcraceandrally.com
  23. Westy
    17,443
    1,103
    Hmm this looks about right. I'll get measuring but I think I might give 15/20 a go.
  24. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    I have the same wheels and run the same width spacers and yeah i think thats just about right.
  25. Westy
    17,443
    1,103
    Ok had a quick measure up and I'm going to go for 15/20:
    Excuse the filthy car!
    Front:
    Rear:
  26. superkarl
    9,467
    2,420
    Do you not think you should prioritise some new trainers???
    16Klappe likes this.
  27. Westy
    17,443
    1,103
    Dude those retro Puma Pele's are my oily car trainers ;)
  28. Alex C
    3,266
    360
    looks about 12mm front to back :)
  29. Westy
    17,443
    1,103
    I was actually thinking 12mm spacers for the front and 20mm rear.
  30. Jason.s
    2,879
    348
    Have fun finding cheap 12s just go 15
  31. Westy
    17,443
    1,103
    You're correct. Cheapest with bolts are £55.
  32. Westy
    17,443
    1,103
    Right, going to order 15/20 right now. Can some please confirm to me the bolt head type for OEM S3/TT wheels please. Radius or Tapered? Ta
  33. IrishDave
    IrishDave Active Member
    682
    45
    Where are you ordering from Westy.
  34. Westy
    17,443
    1,103
    JJC Race and Rally as posted above. Seem to be the cheapest around but a lot of people have vouched for their quality.
  35. IrishDave
    682
    45
    Pretty good prices there. Think I might finally get some myself. Was never willing to pay £100+ for spacers.
  36. Westy
    17,443
    1,103
    I used to have some but sold them to fund PCD adapters for my S4 wheels. When I sold the S4s and PCDs I never got round to buying more spacers. As luck has it I won £82 last night on a work lottery bonus ball thing we do so that'll pay for them. ;)
  37. Westy
    17,443
    1,103
    Anyone?
  38. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    Conical seat for Audis.
    I accept no responsibility if it is wrong, but I did go to my shed and check my originals for you. So it must be right.
  39. Westy
    17,443
    1,103
    Cheers Jardo but is conical a radius or a tapered head? Radius I'm guessing.
  40. 16Klappe
    5,795
    1,184
    Yeah, radius type. Sorry, wasn't really clear then.
    Would be worth whipping out out and checking before ordering?
