Quick Wheel Offset Question
stevereid Mar 30, 2010
  1. stevereid
    stevereid Member
    254
    Quick question folks..would some RS4 Reps, with an offset of 35 fit my 2001 B6 ok ?
    Ta
  2. J7USS
    J7USS Shuddup Foooool!!
    3,737
    76
    Yes providing they have the correct PDC of 5 x 112!
  3. stevereid
    stevereid Member
    254
    yep, they are, was just concerned about the offset,,as I dont really understand it :)
  4. quattrojames
    14,050
    574
    OEM B6 offset is typically 43 - so an offset of 35 means the wheels will "stick out" 8mm further than standard. They will still be well covered by wheel arch though, ideal offset IMO.
    What width are they they? 8 or 8.5 I guess?
  5. stevereid
    stevereid Member
    254
    Hi james, they are 8J width.. that ok ?... just getting some info before I make an offer.
  6. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    With that offset they will sit nice, go for it.
  7. stevereid
    stevereid Member
    254
    They are in pretty good nick, with good tyres... will sleep on it and decide tomorrow.. :)
  8. Syncopix
    Syncopix OEM+
    93
    What's the lowest offset you could reasonably get away with? I have seen some nice wheels that have an offset of 52, but I wanted to space them by 25mm, therefore taking the total down to 27 -- would I have any issues with the arches?
  9. CMD
    3,015
    17
    27 will push the wheel's out to much, i'm running 15mm spacer's on the rear's. 27 offset is to much.
  10. Syncopix
    Syncopix OEM+
    93
    Cheers for the info!
    What offset are you running then?
    Do you have any pictures for reference?
  11. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,382
    111
    im running 8.5j with the et35 offset and they sit lovely, give the car that little bit more stance, wider look but could still go out a bit more if needed but not by alot.
  12. CMD
    3,015
    17
    I'm running 8.5 x 19, 235 tyre (45 offset) with 15mm spacer on the rear's which give's an offset of 30 (inner clearance is a 15mm gain) (Outer postion is 15mm ) No rub what so ever
    and the car is lowered on Eibach pro-street.
  13. stevereid
    stevereid Member
    254
    Just agreed to buy the 18" RS4 Reps on a 35 Offset..picking them up friday :)
