Quick vagcom/map sensor question
loafofbrett Mar 4, 2010
  1. loafofbrett
    loafofbrett Member
    40
    Hi,
    Boost on the car seems restricted some what. Done a vagcom and it's flagging up the following...
    16622 - Manifold Pressure / Boost Sensor
    Signal Too High
    Now, am I right in thinking that if the engine wasn't started and I cleared this code then it should disappear at least until I start the engine? Otherwise if it come back immediately without the engine started then the sensor must be knackered? i.e. it's not the actual reading it's giving causing the problem, more like no reading at all. Hope i've explained that well.
