quick spring question.
Tuffty May 11, 2008
  1. Tuffty
    Tuffty Member
    127
    would std Rs4 springs fit my S4, and would there be any bennifit to fitting them? ie lower ride or stiffer?
  2. Siena
    Siena Active Member
    2,626
    They'd fit, they'll be stiffer, but higher at the front.
    My set-up is Eibach springs for the RS4, and Bilstein Sport dampers for the RS4 too. My front end's higher, but I expected that.
    I also know once my S8 motor, and 6-speed box go in, the front'll settle just fine.
  3. Siena
    Siena Active Member
    2,626
    Where abouts in Suffolk are you? You might be pretty local to me.
  4. Tuffty
    Tuffty Member
    127
    cheers mate,
    why higher at the front? is the Rs4 lump that much heavier than the s4 then?
  5. Tuffty
    Tuffty Member
    127
    I'm just the other side of ipswich from you, nr Hadleigh
  6. Siena
    Siena Active Member
    2,626
    Pretty close then, will keep a look out for your car.
    The RS4 IS a fair bit heavier than the S4, overall.
