quick question
Adam-D Apr 11, 2008
  1. Adam-D
    Adam-D Member
    457
  2. Broken Byzan
    13,237
    465
    Not sure, i thought we used our calipers and bought different brackets to mount them from a TT as they push the caliper further out to accomodate the 312mm discs
  3. docurley
    4,071
    86
    You are correct, he just needs the TT carriers and not calipers and then the A8 discs.
  4. Adam-D
    Adam-D Member
    457
    so those wont fit my car then? at all?
  5. Broken Byzan
    13,237
    465
    Probably, but no good for an upgrade to 312 mm discs without the mounting brackets
  6. Adam-D
    Adam-D Member
    457
    arn't they attached to them already?
  7. Adam-D
    Adam-D Member
    457
    if there is no chance of those fitting my car, what are the part numbers, and the part, and from what car do i need.
    nothing seems to be straight forward on this car. :(
  8. Siena
    Siena Active Member
    2,626
    Adam, as I told you before, those MAY fit your car, with TT carriers and A8 312mm discs.
    But no need, if the calipers are similar to yours, just extra money you don't need to spend.
  9. Adam-D
    Adam-D Member
    457
    does anyone have a part number for the tt carriers? as they will go on my own calipers and that would work wouldn't it?
    if so i need a part number and try to source some.
    getting annoyed at doing anything on this car. everything seems to be a mission of a job :(
  10. docurley
    4,071
    86
    This should be what you want.
  11. Adam-D
    Adam-D Member
    457
  12. Adam-D
    Adam-D Member
    457
    i tried getting the brackets froma vw/audi specialist today and they only list the caliper for that part number.
    does this conversion work??
    does anyone have it on thier car?
    and possibly want to sell it. getting really tired of trying to improve this car. fed up already. all i wanna do is make it stop better.
  13. farmerq
    farmerq New Member
    I may be wrong, but i wouldn't have thought that bigger discs would have that much effect on day to day driving. The pad size is exactly the same, you would just have a better heat dissipator, which should really only come into play under hard sustained braking on a track day or the like.
  14. Adam-D
    Adam-D Member
    457
    im taking it to the nurburg ring in june, a couple of laps then coming back will std size brakes be upto that?
    i may put grooved std disks and uprated pads on, and briaded lines will that be ok?
  15. Broken Byzan
    13,237
    465
    Thats what i did,improved my braking no end ,I will however stick larger on when i need to replace the discs
  16. farmerq
    farmerq New Member
    Thats a different story. well if you're going to the nurburgring i would definately look at upgrading the brakes pads. Standard road pads are not designed for track use
  17. Adam-D
    Adam-D Member
    457
    was looking at ebc greenstuff, or similar, i wont be hammering it as its my first time round there.
