Quick question while the bonnet is open!
Westy Feb 8, 2011
  1. Westy
    Westy Well-Known Member
    17,443
    1,104
    What diameter of hose can i use for the actuator to N75 connection?
    I'm just giving all the hoses a once over to try and hunt any splits.
  2. shanejess
    shanejess Guest
  3. Westy
    17,443
    1,104
    are you 100% sure? It looks bigger than 4mm!
  4. coyle
    coyle From Show... to GO
    435
    silicone stretches, ive used some 3mm silicone on a 6mm fitting before
  5. shanejess
    shanejess Guest
    i told my wife this, she says you carnt put a pin were a nail has been.
  6. Westy
    17,443
    1,104
    honestly the 4mm hose i've got wont go over! anyway think i might have found a split elsewhere. cheers guys.
  7. J B
    J B Member
    140
    Think 6mm should be good, I took out all the N249 stuff earlier and removing all the PVC pipework because I still havnt fitted my oil catch can! I was just getting to the N75 bits as it got dark so gave up but should be able to confirm tomorrow if the weathers alright!
  8. shanejess
    shanejess Guest
    its 4mm, likes to be bathed in hot water 1st though.
  9. coyle
    435
    i fitted 3mm when doing the n249 bypass.
    ive got a few metres of 5mm and 8mm to do a few other bits
    id like to get rid of the SAI and PVC pipework, but dont have a clue where to start (and ive read the guides already lol)
  10. J B
    J B Member
    140
    Yeah 3 or 4mm is fine for the N249 bypass (inlet manifold to the DV) but cant see that being the right size for the the N75 to the actuator think it needs to be just a bit bigger than that!?
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It is more like 8mm, hes not doing the n249....:think:
  12. Westy
    17,443
    1,104
    Correct Dave. I wanted to replace the hose that goes from the actuator to the N75 valve. I think the hose is ok but thought i'd change it while I was there.
  13. coyle
    435
    in that case yes its 8mm
