quick question on the s3
S3MHT Oct 7, 2006
  1. S3MHT
    S3MHT Remap Do I or Don't I???????
    121
    Just a quick and simple question as im in a debate with someone, Is the S3 permanent 4 wheel drive (which is what I thought) or is it only 4 wheel drive when needed? thanks
  2. Quattro_Lew
    Quattro_Lew All Torque
    206
    permanent mate
  3. colinra
    colinra Member VCDS Map User
    91
    only when needed
    when the front wheels start to slip the rears are fed power via the haldex system.
  4. S3MHT
    121
    Ahhh great mixed opinions on here too!
  5. madvw
    madvw Active Member
    2,489
    read up on the differences between haldex and torsen quattro if you're interested.
    you have a haldex in the S3, i.e. FWD until front wheels slip or full throttle, then 4wd.
  6. Quattro_Lew
    206
    well ill be damned i never knew that!
    is that the same for mine? (quattro t sport)
  7. madvw
    madvw Active Member
    2,489
    All 'quattro' A3/s3's (8P and 8L) and TT's are haldex, not torsen.
  8. S3MHT
    121
    So its official then its only 4wd when needed!!!!!! thanks another agument i've lost lol:mad:
  9. PaulRS3
    PaulRS3 Well-Known Member
    1,215
    149
    it is as above, but dont udersetimate it, its 4x4 more than you think.
    Even more so when remapped.
    mash the throttle, even in the druy, and your soon in 4x4.
    its easier to detect when haldex is disabled, (ie when handbrake is up a one notch, haldex disables on braking signal) then when its active.
  10. Wicked666
    Wicked666 Active Member
    584
    35
    surely haldex is better as the proportion front/rear split is determined by the road surface and driving style?
  11. mattyboy199
    mattyboy199 Well-Known Member
    1,892
    30
    i m sure the there is always 5% going to the rear.
