Quick question about fitting a TIP to my 1.8t quattro....:)
Mk1magic Apr 8, 2013
  1. Mk1magic
    Mk1magic Member
    65
    Hi, I brought this from ebay last week for a bit of a bargain[​IMG]However, I have noticed that there is 2 large inputs on the tip, one that the DV fits into and the other...well I have no idea. Ive looked at the standard item and there is a small pipe on the left that looks as though its in the same "area" but far smaller..?[​IMG] Have I brought the wrong TIP or am I jus not looking hard enough? Any help would be most appreciated :D cheers
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Just block it of and to the catch can mod, or get an adapter,it looks like its the port for the breather system, not sure why it is so big though..
  3. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    as dave said one will be for the PUK (breather thing, fit a catch can much better) the other is for your DV :)
  4. Mk1magic
    Mk1magic Member
    65
    I was thinking of doing the catch can mod but probs a little later on, I assume the standard pipe that goes to the puk would easily slip in to that other hole on the tip. So I take it that small pipe in the right can just be blocked off...?
    cheers
  5. s3dave
    10,110
    736
    Nope the small pipe is for your n75 valve...
  6. Mk1magic
    Mk1magic Member
    65
    Any sort if idea wherein could get an adapter that would fit both, are we talking just a small plastic adapter from halfords etc?
  7. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    you can still fit it ok, you have two large holes in your new TIP, one for the DV and one for the breather system. The other small hole on the TIP that is staring you in the face in the picture you have posted.... stick the n75 in there
  8. Mk1magic
    Mk1magic Member
    65
    I saw that and did consider putting it in there with the others, was just puzzled as to why the "breather" hole in the new tip was so large n what went in there ;)
