Quick Brake Pad Question
gaz_hughes May 10, 2007
  1. gaz_hughes
    gaz_hughes GumbyGaz
    20
    Just looking at ordering some new pads for my 1.8TQ, but been asked at ordering if mine are the pads with wear indicators on both pads or just on the one pad.
    Anybody know?
    Tried searching the forum but can't find confirmations. Audi said they're both sides, but the bloke on the phone didn't sound that sure of it.
    Gaz
  2. dan_a3
    dan_a3 Member
    196
    Do you mean 1 indicator per pad or 1 indicator per side? Im not 100% sure but normally on each wheel one pad has the indicator and the other doesnt. Be careful as there are 3 styles of plugs on the indicators.
  3. rodenal
    rodenal Active Member
    1,992
    Hmmmmmmm from memory its 1 - i wouldnt even bother buyin those pads if i were you just get some without the indicator
  4. gaz_hughes
    gaz_hughes GumbyGaz
    20
    Oh right, not as simple as I first thought then!
    The bloke one the phone seemed to suggest 1 indicator for each side. Nothing about different connectors? Hopefully they'd be the right ones with correct style plugs.... Didn't even know there was variations...
    Which pads do people usually go for?
    If I went for pads without indicators, would that annoying (o) symbol still be on my dash?
    Cheers!
  5. jonS3
    jonS3 Member
    719
    no, the symbol won't come in as long as you snip the old connector off from the pad leaving ebough of the wires to be able to crimp them together. then waterproof it and connect it to the car harness. this will make your car think your pads are fine as there will be a constant circuit.
