quick brake caliper question.
cjhill Jun 19, 2007
  1. cjhill
    cjhill hmmmmm interesting.
    335
    If i remove my caliper from the car, i.e disconnect the brake line, when i refit it would it be ok to just flush that particular caliper to get it working again.
    or will i get air in there that i wont be able to remove. Of course i would have to stop the rest of the system emptying whilst i work on the caliper.
    Cheers.
  2. jojo
    28,982
    3,626
    You will need to bleed that caliper again, as air will most probably get in there.
  3. dan_a3
    dan_a3 Member
    196
    And have heard of alot of people getting air trapped in the ABS system which can be fun to get out, so be careful.
  4. inigoj
    inigoj Member
    263
    Ensure you disconnect the battery before removing the caliper.
  5. Ess_Three
    Ess_Three Active Member
    5,383
    Why?
    I've never done that, ever.
    If you have rubber flexys on, you could use a hose clamp to stop all the fluid draining out, and air getting into the ABS pump.
    If you have steel braided flexys on, you're going to have to use a pressure bleeder to try to avoid getting air trapped in the ABS pump, or cycle the ABS pump using VAG Com or similar.
    Personally, if I'm doing any work on the brakes, I'll flush the fluid through each calliper at the end of the job...fresh fluid is always good!
  6. S3_MCD
    S3_MCD Member
    389
    never done that either?!?
    would suggest that before reconnecting to the caliper bleed the hose...and then bleed the caliper.
  7. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Just clamp the hose with a brake pipe clamp..[​IMG]
    Or a pair of mole grips with something around the pipe so as not to damage it. and when you reconnect the caliper just bleed it and job's a good un
  8. Caesium
    4,879
    Please could you supply a reason for this?
  9. inigoj
    inigoj Member
    263
    I do not like using hose clamps, so disconnecting the battery ensures that air will not enter the ABS pump.
