Sammyfat
Hi
i have a completely standard 2007 s3 and the clutch is on its way out so I'm nursing it until I have enough pennies to buy a new one.
so what do I buy??
Do I keep a oem type one? Which everyone states is a bit poo and weak.
or do I go for a performance clutch spend a lot more but in the long run lasts longer etc I might do a remap later on. Not sure??
i have a quote from a local specialist £1500 job lot.
this is for;
- 6hr labour (quite a lot of work apparently ,subframe down, gearbox out, realignment etc)
- Sachs performance clutch 400lb/ft kit inc single mass flywheel 02Q (this is £940)
- clutch release bearing and slave cylinder - luk
- 6 flywheel bolts 02M 6spd
- 6 clutch cover bolts
So is this quote expensive? Or reasonable?
is this clutch a decent one? There's so many to choose from Im confused?
thanks Sam
so what do I buy??
this is for;
thanks Sam
