Question regarding the 312 caliper holders
abpostelnicu Mar 21, 2010
  1. ste
    ste reverse gear
    121
    hi mate, just had a look at your purchase and everything is there u need to bolt them straight on. good buy!
  2. Are you sure that there are also the caliper holders?
  3. ste
    ste reverse gear
    121
    yes. u can see the bolts screwed into them. they will bolt to your existing baering housing when you remove your old calipers:yes:
  4. THANKS :)
  5. NHN
    29,551
    1,777
    Yeap carriers are there as far as I can see, also I know that guy personally, he's a great guy & parts have always been spot on trust me.
  6. hello guys ive just bought the carriers and calipers for the back side from an audi a3 2.0 tdi 170hp what else do i need to retrofit them on my 2.0 tdi bkd. also what size are the discs?
  7. some help?
  8. L80EWY
    L80EWY Active Member
    406
    68
    Rear discs are 255mm iirc
  9. are uou sure that the audi a3 2.0 tdi BMN 170hp has 255mm discs and not 286 like the gti does?
  10. Rob-Quattro
    Rob-Quattro Member
    225
    13
    Just measured my old 170 rear discs and they are 286mm. :)
  11. thank you do you know if a need anything else, more tahn the pads, discs, caliper and carieer, in order to retrofit to my 2.0 tdi BKD 140bhp that has 255mm discs?
  12. Rob-Quattro
    Rob-Quattro Member
    225
    13
    I've just upgraded mine to s3 all round, I wanted to keep it looking OEM so brought the disc shields/guards from Audi as your standard ones will be to small. Some people just bend the standard ones back so they don't rub on the new disc but I suggest buying new ones. Not alot of money but worth it. All the bolts will be the same but you will want new caliper to carrier bolts (unless buying new pads, then they come with them).
  13. L80EWY
    406
    68
    Ah sorry I must have been looking at 140 brake discs not the 170s
  14. Just installed front plus rear with brand new discs and pads manufactured by trw. I didnt have time to test them very well since here its raining but a first glance the braking is phenomenal :).
    Sent from my GT-I9100 using Tapatalk
