Question regarding "Coming home lights" Black Edition
Avus Sportback Oct 30, 2011
  1. Avus Sportback
    Avus Sportback Member
    116
    Guys,
    I have just retrofitted the coming home lights mod to my Sportback Black Edition (Xenon LED DRL's), and all is working fine. Just been driving home in the dark now and realised that my light position switch was set on DRL'S but yet my Xenons were on?
    I didn't think my car had "Auto" lights and I'm sure it's only done this since the mod, previously I'm positive my Xenons wouldn't have come on unless I selected dipped beam on the switch!
    Am I going mad or have they always been automatic?
  2. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,246
    340
    i thought all xenon's were auto lights mate lol
  3. Avus Sportback
    116
    I know they are Auto levelling but don't think they are auto on/off.
  4. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Na... When I ordered my BE I had to pay extra for auto lights and wipers.
  5. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,326
    188
    The clue is on the switch...does it say AUTO as the first position ( mine does)...better still have you got auto wipers and the sensor on the screen behind the interior mirror ?
  6. Avus Sportback
    116
    No, don't have auto lights or wipers.
    Why is the DRL position turning my Xenons on then?
  7. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    I've just helped someone out whose lights were on even when the switch was turned off.
    First check with VCDS for error codes.
    Secondly, have you had the main light switch apart to do you changes. If so its likely like the bloke I saw it hasn't gone back together properly.
    What did you change to do your retro fit?.
  8. Ash187
    7,505
    748
    normally if the xenons come on when they are 'not meant to' its a fault on the car. could be wiring or coding depending on what you have done to it.
  9. Avus Sportback
    116
    Just fitted the wire into Plug E Pin 12 and earthed it. Then went into VCDS and enabled coming home lights in central electrics Byte 05 and 07.
    Is that correct?
    Link to the mod here cominghomelights - Audi Retrofit
  10. Ash187
    7,505
    748
    does your headlights come on whilst the swtich is in the DRL position in the daylight?
  11. Avus Sportback
    116
    Not sure, will check tomorrow. The wife has had the car all day....
    Will check later for fault codes
  12. Avus Sportback
    116
    Ok guys, finally sorted it....It appears that with the LED DRL'S you don't have to check Byte 5, only Byte 7
    All working as it should now, thanks anyway :arco:
