Question for those in the know - A4 remaps
Av4nt Sep 11, 2012
  1. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro s tronic saloon
    1,511
    387
    I am thinking of remapping my A4. could you advise of a few decent places that can do decent remaps please?
    Are revo generally the best about as this seems to be the choice of most.
    as its a stage 1, Am I right in thnking that I wouldnt need to upgrade anything on the car like you would to carry on to stage 2?
    and for a stock turbo, would a remap put added pressure or wear on it? My car is on 124k and still running on stok turbo.. with this in mind is it wise to remap with that turbo or does it not make a difference.
  2. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    If you car is well maintained, i.e. regularly serviced and looked after when problem arise a remap should have no effect on it's reliability. If however the added power of a remap makes you change your driving style (more right foot) that is what will cause more wear etc, as it would without a remap.
    Engines are built well within a tollerance and to meet EU standards amongst other things from the factory, a remap's main source of power gain is adding about 0.15bar to the turbo boost, then adjusting fuel ratios and timings etc to compensate and make the most of the engine.
    If you have existing problems with the car, a remap will only make them more noticable, not cause them. Go for the remap! Where are you based?? R-Tech in Hinckley are excellent from personal experience, but it depends where you are...
  3. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,280
    616
    What engine is your car? Petrol or Diesel? Power?
    Diesel engines do not rely so much on boost increases as do petrol cars. Diesel turbos are also much less tolerant to boost increases compared to petrol engines in terms of durability. Let us know your exact spec and we can advise. Stage 1 and 2 are essentially marketing terms and don't mean a great deal. A completely standard car can be remapped, we adjust the map to match and and all specifications.
    Thanks, Rick
  4. Av4nt
    1,511
    387
    Mine is a Diesel 2.0 TDI. And stock 140bhp. B7 2005.5
    I did have a speedhawk xxl chip on it, which made it boost a shed load but I removed it for fear of prematurely killing the turbo.
    That being said I put it on to save fuel as opposed to being right foot heavy.
    Im in norwich, but I travel to manchester alot so i guess that opens up flexibility in where I could go.
    It may be worth noting that when I got the car I did have some problems with it. Im pretty sure the prev owner did not take it for servicing as often as it should have been.
    since I have had it its had a top engine rebuild and a new cam belt and kit (due to snapped cam tensioner bolt)
    new EGR valve unit and a re wire of a part of the electrical system due to a fault.
    I have had a cat back quad tip exhaust fitted recently also.
  5. lr02lee
    lr02lee New Member
    I'm from Manchester with exactly the same car as you. I'm going for a remap at awesome gti not far from the Trafford centre shopping centre.
    Heard great things about them as a company and have all singing and dancing equipment there, plus it's always has a few cars there to ogle.
  6. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
  7. Audi Dynamik
    2,218
    308
    Or Apr seems a good choice.
  8. Rick @ Unicorn Motor Dev.
    1,280
    616
    Well we are in Stockport so very close to you also. Our maps are written in house and fully customised to your car if you want something a little more special than a generic stage 1 map :) I would also highly recommend having the EGR valve disabled for long term reliability and drive ability.
    Thanks, Rick
  9. .Jas.
    .Jas. Member
    134
    Rick, when you map out the EGR valve do you blank it off? Rason for asking is (i'm not sure on this yet) but my EGR valve might be playing up. Therefore if you just map it out it might still cause problems?
  10. Rick @ Unicorn Motor Dev.
    1,280
    616
    Hello Jas,
    yes we blank it out. However, you can get away with not blanking it depending on what is wrong with it. If it is stuck shut (which is the most common) then the map is all you need. However if it is stuck open it needs blanking.
    Thanks, Rick
  11. .Jas.
    .Jas. Member
    134
    Hi Rick, I get intermittant lumpy running from cold until the engine is warm. I think mine might be stuck (or sticking) shut?
  12. Av4nt
    1,511
    387
    Rick, are you able to Pm me with some more info and a rough quote for a standard stage 1 remap?
    Ive also had a new EGR valve unit fitted within the last couple ofm months. Cheers
