question for badger 5 or anyone else with engine experience
djdougalno1 Aug 1, 2010
  1. djdougalno1
    djdougalno1 Member
    189
    right ive got a 99 a3 qts with engine code ajq i recently did a k04 conversion inlet mani injectors etc mapped buy amd with 4 bar reg also 3" dp but im not that impressed so im thinking about a gt28rs as theres a company doing a bolt on kit using existing mani and dp im going to upgrade the rods anyway but wondering wether the pistons needed to be changed as i belive the comp ratio is higher in my car compared to s3's etc or would the standard pistons be ok and same for the valves is standard ok for this turbo any help greatfull
  2. Speedy Steve
    Speedy Steve Active Member
    1,258
    I wouldnt use the factory manifold its seriously restricting on my Hybrid so on a 28 it will be even worse
  3. Andrew@A.L.D
    3,879
    617
    When you say your not impressed what do you mean?
    Not impressed with the power, the way it drives etc?
  4. djdougalno1
    djdougalno1 Member
    189
    yep just feels slow it made 250 odd bhp and about same torque the best times i can get on the quater mile are 14.59 and i wana be in the 13s at least so more power needed
  5. Andrew@A.L.D
    3,879
    617
  6. djdougalno1
    djdougalno1 Member
    189
    i have a printed graph if thats what you mean somewhere
  7. Andrew@A.L.D
    3,879
    617
  8. djdougalno1
    djdougalno1 Member
    189
    found the print out there is 2 runs
    run 1 247hp 249lb ft @3869rpm
    run 2 245hp 256lb ft @3487rpm
  9. djdougalno1
    djdougalno1 Member
    189
    do you wana see it if so ill take a photo an post it
  10. Andrew@A.L.D
    3,879
    617
  11. djdougalno1
    djdougalno1 Member
    189
    here we go not great pic
  12. djdougalno1
    djdougalno1 Member
    189
    hope this helps then so what can you tell me from this
  13. badger5
    9,601
    2,060
    Is this "kit" you refer to an eliminator 2 kit or CTS Turbo one?
    the k04 conversion you mention was an actual K04, with k04 manifold etc yea? The eliminator 2 I think are for K03 installs... not sure if they offer an Eliminator 2 kit for K04 (225 engines)
    pistons should be ok, mapping to suit, and rods are a good idea.
  14. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    28 won't flow much more, if any, than your hybrid mate to be fair.
  15. djdougalno1
    djdougalno1 Member
    189
    this is the turbo i was looking at http://cgi.ebay.co.uk/E2-GT28RS-20V...arts_Vehicles_CarParts_SM&hash=item27a9faf46e
    also yes i did use a realo k04 with k04 mani also 225 intake also what do you think off the turbo a waste of time or potential honest awnsers please and what sort of bhp do you recon
  16. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i belive you would be better off going hybrid on the k04, eliminator turbos are supposed to be laggy so you would benefit more from hybrid and you would be seeing similar figures to that of the gt28 would also work out cheaper as you have the k04 setup anyway
  17. badger5
    9,601
    2,060
    i cant tell from the pictures wat it is.. not enough info
  18. djdougalno1
    djdougalno1 Member
    189
    ok cheers i think ill just go for the ihi conversion then
  19. djdougalno1
    djdougalno1 Member
    189
    i did speek to them a while back they said it was a gt28rs or gt2871r that had been adapted tofit the k04 mani and downpipe if that helps
