Question About Xenons - Keep getting flashed.....and not in a good way !!
haywoon Nov 19, 2010
  1. haywoon
    haywoon Member
    49
    I have factory fit Xenons on my S3 and when driving at night I'm getting flashed by some oncomming cars as if my lights are on high beam.
    Initially I thought it was people flashing to say wow look at that gorgeous man in that amazing S3....but then I looked in the mirror and concluded that cant be the case......
    The car went through MOT in Sept with no advisories - the beam isnt pointing into the sky, but I think it might be a gnats knacker too high.
    Would any form of diagnostic system pick up a fault at all?
    Can xenons be adjusted? I thought they were auto adjusted by the ballasts fitted? Assume the sensor can go t1ts after a while and need replaced maybe?
    The car is lowered - maybe that has sommat to do with it????
    Any help much appreciated.
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    :laugh: lights need put into learning mode via vagcom and then readjusted due to the lowering mate
    if youre in vagcom the procedure is 55.Xenon Range > Basic Settings > Group 001 and hit go, readjust the height and then exit vagcom and youre done. happy motoring
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    You'll find people just find them too bright & assume you have your main beam on. Flash them back LOL
  4. haywoon
    haywoon Member
    49
    Nice one - cheers for that.....
    I'll do some Vagcom research next....My mates lad has got VAGCOM I think....I bet he'll have a look at it for me for a couple of cans of white lightning or what ever it is the yuuuuufs drink today....
  5. haywoon
    haywoon Member
    49
    Yeah been doin that LOL dont wanna give us S3 drivers a bad name though
  6. AuldReekie
    AuldReekie Member
    770
    I noticed you have coils fitted; when I fitted the H&R springs I had to get my lights re-adjusted on a light box and again after I fitted my PSS10s. First time I took it to Audi as it was in warranty, the second time I took it to a mates garage and did it there. I know that others who have lowered their '3 have had to do the same.
  7. haywoon
    haywoon Member
    49
    Cheers mate.....
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    sounds like a plan give me a shout if you get confused but follow what i put down there and you cant go wrong
  9. Brett Butler
    Brett Butler Member
    664
    13
    Take the Big Safe out of the boot :)
  10. 8ig_steve
    8ig_steve Member
    39
    Just in the hope that I might learn something.
    How does lowering the car affect the angle of the headlight, surely they would be the same angle just a bit lower which would make the beam hit the ground just a bit nearer the car??
  11. sub39h
    sub39h Active Member
    2,502
    that's what i was thinking
    at a guess i'd imagine that because the car won't necessarily be levelled exactly 30mm or 40mm or whatever at each corner (deliberately or otherwise) the auto levellers try to adjust and point the beam upwards inappropriately
  12. haywoon
    haywoon Member
    49
    Off to have the car plugged into VAG-COM this afto....will report back in after thats been done to let you know the result....
  13. haywoon
    haywoon Member
    49
    Been to a good mechanic I know - no requirement for VAGCOM on this occasion - just a few manual adjustments required on the headlights whilst pointed at the MOT testing device and perfecto.....no more peeing off oncoming drivers
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    as long as they dont readjust cant remember if they do or not
  15. haywoon
    haywoon Member
    49
    Bl00dy hell I hope not !!! Mind you, he isnt far away from me so if they do, I'll ask them to do the VAG-COM option ..... its one of those awkward situations where you dont want to be seen to be telling someone how to do their job LOL !!
  16. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha aye if it adjusts back say you looked into it and print off the procedure from the rosstech wiki theyll be thankfull that youve had a look and as its ross tech not your instructions you aint telling them ;)
