Question about S4 suspension
jetspeed May 10, 2004
  1. jetspeed
    jetspeed New Member
    27
    I was curious as to what kind of suspension the S4's have, is it similar to what I have on my A4 which is the sport suspension? Or is it something completely different? Is it lower than a stock A4? Sorry for the ignorance, but I'm new to the Audi club......
  2. Markey
    Markey Active Member
    2,175
    It is stonger because of the S4s engine and stiffer because of that.
  3. ImolaS4
    ImolaS4 Member
    275
    and lower by approximately 1.25" than the standard A4 suspension. It has to be stronger up front because the 2.7T engine is heavier than the 1.8T, but many people swap S4 suspensions onto A4's with 2.8 engines without any compromises. The S4 suspension, all in all, is a stiffer suspension (slightly stiffer than the Sport suspension). BTW: the height difference between the Sport suspension and the S4 is roughly .25 - .5 inches (the S4 being lower).
  4. Mutinyno9
    Mutinyno9 Member
    248
    Would the S4 suspension on a 1.8T be fine, or only on a similar size engine, or does it matter?
  5. ImolaS4
    ImolaS4 Member
    275
    [ QUOTE ]
    [/ QUOTE ]
    It will fit (B5 chassis). It will be stiffer (even more stiff up front). It will lower the car by about 1 to 1.5 inches (depending on how settled your OE suspension is at the time). It only matters if that's not what you want. Best advice, if you go with it: put a 19mm sway bar in the rear to compensate for the understeer. It will dial in the suspension better with the sway bar.
