Question about S3 lights.
Effect Jun 28, 2007
  1. Effect
    Effect Member
    469
    I have xenons as main beam and crappy yellow lights for eveything else.
    What i would like to know is what bulb colour temperature to order for the sidelights, high beam and fogs and what type of bulb they are ?
    James
  2. QUATTRO_REP
    QUATTRO_REP Diesel Power!
    229
    4300k is the OEM colour temp for the hids i think.
  3. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Check out this thread http://www.audi-sport.net/vb/showthread.php?t=30256
    I went for the PIAA Xtreme Force 4700K, H7 for Mains, W5W for Sides. Can't remember the fogs but have a look in the manual.
    By the way changing the bulbs were a right b@stard!!!!
  4. golf
    golf ***** rent boy VCDS Map User
    1,556
    FYI bulb colour temp is really only applicable to genuine xenon HID's.
    Get some PIAA sidelights, and avoid LED's as they burn out very quickly or start flickering. The new thing to do is get 3000k xenon's for the fog lights for that old school bright yellow 80's look.
  5. silver75
    silver75 Big Ron
    3,265
    or the PIAA TERRA LEDs
  6. Effect
    Effect Member
    469
    when you say mains do you mean high beams ?
  7. mattyboy199
    mattyboy199 Well-Known Member
    1,891
    29
    any PIAA led sidelight should last years mine have (S3)
  8. Effect
    Effect Member
    469
    cant find out what bulbs i need to change for the high beam ?
    All websites seem to say different.
    As I said I have xenons so only need to change one pair of bulbs, some websites are suggesting H4 which cant be right as they are twin filament bulbs for high/dipped beam.
  9. Effect
    Effect Member
    469
    Does anyone know what bulbs i need to buy ??
  10. S3Steve
    S3Steve Active Member
    1,622
    20
    The main beams on the S3 headlamps are H7's, personally i am running some PIAA Extreme White Plus bulbs, which are listed as 4000k and are fairly close to the white of the HID bulbs, hope this helps mate.
  11. S3Steve
    1,622
    20
    Its also worth changing the side light bulbs at the same time to complete the "white look" they are W5W fitment. Also if you are gonna go the whole hog the fog lamp bulbs are also H7's
