pangsterA3
Hi - I've just received my KII dongle from Ross Tech and ran my first scan - the log details are below:
I managed to find entries for 3 of the faults:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!):
http://wiki.ross-tech.com/wiki/index.php/17705/P1297/004759
17545 - Fuel Trim: Bank 1 (Add): System too Rich
http://wiki.ross-tech.com/wiki/index.php/17545/P1137/004407
18010 - Power Supply Terminal 30: Voltage too Low
http://wiki.ross-tech.com/wiki/index.php/18010/P1602/005634
I'm not sure how old these are so I've cleared them (there was no Check Engine Light illuminated) and there hasn't been in the last 2 weeks. So I figured I'd clear them first and then check in a week or so and if they return, investigate further?
I'm not too concerned around the 5 central locking faults at the minute as I don't know how old they are and they seem to be quite common on the logs (so I cleared these as well) - the alarm fault was triggered by me last week when I was checking the alarm! LOL!
But the one I really want advice on just now is the Airbag fault:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
32-10 - Resistance too High - Intermittent
There is no mention of this on the Ross Wiki?? - I think this was also the cause of an intermittent Air Bag light coming on in the dash at the weekend. It was the first time the Air Bag light had came on in the car and it was also the first time I had someone in the back of the car - they were also sitting in the rear seat (passenger side). At first, after reading posts on here I thought it might have been the cables underneath the passenger seat being upset - although this now appears to not be the case.
At present there is no Air Bag light on and it only came on and off intermittently when someone was sat in the back seat - has anyone had this fault before or can they advise me on likely cause/fix for this??
Thanks in advance!
Wednesday,26,October,2011,20:24:44:33950VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ11002328
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 FC
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 01236
VCID: 64C9AF54DEC0
WAUZZZ8LZ11002328 AUZ7Z0A1800155
3 Faults Found:
P1297 - 35-10 - - - Intermittent
P1137 - 35-10 - - - Intermittent
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 01236 785 00200
VCID: 2C590774F690
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 01236
VCID: 2F631078C786
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 01104
Shop #: WSC 01236
VCID: 458F52D0753A
1 Fault Found:
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 E
Component: AB-KOMBIINSTR. VDO D12
Coding: 00444
Shop #: WSC 00618
VCID: 356F221025DA
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 01236
VCID: 2F631078C786
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0C123444AD8
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
End ---------------------------------------------------------------------
Thanks in advance!
