Quattro - What to do???
dobber Apr 17, 2008
  1. dobber
    dobber Member
    41
    I need new tyres soon - Is it ok to get 2 new ones for the front or should i get 4 new around?
    Is the Goodyear a hard wearing tyre - i know everyone rates them.
  2. phantom
    phantom On Boost
    1,750
    If your rears are low then you SHOULD get all 4 , coz your fronts will have 8mil and your rears 2mil.
    p
  3. dobber
    dobber Member
    41
    EH???
  4. phantom
    phantom On Boost
    1,750
    I'll make it easy for you, in a ideal world replace all 4. If your rears are very low say 2mil replace them as well.
    If you still have say 5mil on the rears you may be ok just changing the fronts!
    p
  5. richs2891
    richs2891 I cant spell !
    441
    Thats why its suggested to rotate the tyres front and rear so get even wear over 4 tyres ! Ok it cost you more when swap but then dont end up with as above 8 mill on front and 2 mill on rear - which could lead to interesting handling
    Richard
  6. newbiecrg
    newbiecrg windsurfer
    1,328
    with the haldex quattro is is fine to change at different times, make sure you change at the same time the ones in the same axle though...
    Pedro
  7. Dandle
    Dandle Member
    852
    Check what the wear is on the back because when we changed our tyres(early to fit winter tyres) after 6k miles there was only 0.5mm difference between front and rears.
  8. dunk
    dunk Member
    770
  9. newbiecrg
    1,328
    true that... my front tires are well within the limit but the rubber is not as grippy as when new... and towards the end of the life the grip is not as good as it was...
    Pedro
  10. EddyH
    EddyH Member
    67
    Changing in pairs is fine but the new tyres should always go on the rear for safer handling; so move the part worn rears to front when getting the new tyres.
  11. marriedblonde
    marriedblonde Active Member
    4,371
    Here we go again... New tyres where debate... :)
  12. newbiecrg
    1,328
    I am not even going to say anything.... lolol how many pages last time?
    Pedro
