Quattro Tyres
buttons89 May 29, 2013
  1. buttons89
    buttons89 New Member
    17
    Hello!
    For my first post I'm probably about to kick up what seems to be an ongoing uncertainty around Audi forums!
    Got myself a MY10 A3 Sportback 170PS 2.0tdi quattro BE just over a month ago and I've just noticed these cracks on both rear tyres on the tread/sidewall transition and circumferentially on the inside tread groove. Running Bridgestone Potenza RE050A 225/40/R18 92Y. I am uncertain of the tyre usage from the previous owner or what comes as standard on these models, however the car was barely used by the previous owner (12k miles when I received it).
    Wondering what people's thoughts are on this, advice with changing tyres on quattro systems with regards to changing axle pair/all 4 corners, different brands front/back, recommended tyres? Will probably be going to a local tyre shop to get a quote at the weekend :(
    Any help will be much appreciated. Will hopefully get round to a happier hello post with some nice pictures in the near future!
    P.S. Very good forum.
  2. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    welcome to the forum, tyres crack like that with age, there are date stamps on the tyre as follows
    Tire Tech Information - Determining the Age of a Tire
    just get them changed, you've said your self the car has had little use, and the tyres have clearly been on much longer then the tread would have lasted if they were in constant use. ive seen worse but its a mot failure as far as I understand.
    this isn't a common problem to this car or any per-se, just a common problem for tyres as a whole.
    just change all four as there all old by looks of it
    edit, looking at the pictures, the tyres were manufactured week o of 1990. so the tyres are 13 years old.
  3. NHN
    29,576
    1,779
    Contact Bridgestone with photos & see what they say.
    I use Vredestein Sessanta's atm, good on wet & dry, the latest versions are called Vorte's iirc.
  4. buttons89
    17
    Definitely changing then!
  5. NHN
    29,576
    1,779
    Think you mean 23 years old, which would maybe explain why they have gone this way, but I cant see it somehow on a 2010 car, I doubt it.
  6. chinnyhill10
    chinnyhill10 Member
    154
    You are supposed to change tyres per axle on the A3.
    However I had my car MOT'd today and my 2 front tyres are on different wear rates (1mm difference). As both were replaced at the same time I think we can assume a few mm out on each tyre isn't going to be a problem!
  7. Graham22
    Graham22 Member
    39
    That's not the date stamp in the pictures, is usually just 4 numbers and nothing else.
    My friend had the same problem with Bridgestones fitted to the rear of his Honda Accord, less than 3 years old & cracking very bad.
  8. boost-addict
    1,000
    39
    could be part worns or what ever that were put on it, who knows. any thing is posible.
    the date stamp is there right next to the dot stamp
    unless thats the 9th week of 00 which i guess would match up to the cars age.
    i guess if it hasnt had use it can crack up from no heat cycles
  9. crunchie
    crunchie Active Member
    880
    77
    Looks like week 40 2009 to me :-/
    Do you seriously think they made Potenza RE050's in 1990 :banghead:
    They will be the originals, just get them changed out for peace of mind.
    I wouldn't want to go any further than the shops with them on tbh.
    NHN likes this.
  10. boost-addict
    1,000
    39
    possible, i didnt look what tyres they were. so bang ya head all you want
  11. audicruiser
    audicruiser Audi Heaven
    1,865
    What the mileage on the car as they may be the originals as those tyres were fitted at the factory from new in 2010....
  12. boost-addict
    1,000
    39
    12k miles ;)
  13. chinnyhill10
    chinnyhill10 Member
    154
    I used to know someone who said certain tyre dressings were really bad for the rubber. May or may not be true.
    We used to have a Jag with 30 year old tyres on it. Car had only done 18k and only failed on the tyres when one of them ruptured. Go figure!
  14. boost-addict
    1,000
    39
    that just depends mate, was this jag kept in a garage?
  15. buttons89
    17
    Thanks for the replies. There has been a tyre change at some point as the fronts are newer and in better nick, DOT codes 4611 and 3012.
    Any more thoughts on recommended tyres etc?
  16. chinnyhill10
    chinnyhill10 Member
    154
    Garaged up. In retrospect it seemed stupid to keep tyres that old but in those days you didn't question it unless it failed an MOT.
  17. boost-addict
    1,000
    39
    then the tyres wouldnt be susceptible to frost
    and i wouldn't be surprised if it was a heated garage too
  18. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,875
    665
    I don't know but I was told by the lads that do the tyre changing for Audi near where I live that if there is a 1mm difference front to back with the A3 quattro system then you should replace all four so the Haldex isn't being abused and running when it's not actually required.
  19. buttons89
    17
    Daggerit, notice you are in Aberdeen too. Who do you recommend round here for tyres?
  20. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    perhaps used on track day event.
  21. chinnyhill10
    chinnyhill10 Member
    154
    Sounds like a nice little earner for them. "Yeah guv, you'll need 4 new tyres rather the 1 you came in for".
  22. buttons89
    17
    So after a phone call or two to the dealer, the end result...two new tyres on the back (same Bridgestones) courtesy of the dealer, who also collected and dropped off at work. Only complaint was getting a wee VW Up courtesy car after requesting a larger car! So I've got some extra pennies for a beer or two :beerchug: thanks for your advice! Will hopefully get the car cleaned at the weekend after ordering a bunch of Dodo Juice products and post a few photos.
  23. The Governor
    The Governor Active Member
    528
    75
    I imagine they say that while relentlessly pounding your ****.
    Unless you're driving at the limits of grip, I can't imagine the Haldex being affected at all really... I'm going to be swapping my fronts before my rears, at least according to current wear rates, and I won't be letting the tyre fitters spit-roast me in the process :D
    autolatry likes this.
  24. Daggerit
    1,875
    665
    Not really because I was on the Audi complete package so they were essentially paying for them on that occasion. Putting two on would've saved them spending as much money, hence the reason I believe it.
    The reason I looked at the tyres and took it in originally was because I could feel like the FWD was coming on and off which is apparently a symptom...
