Quattro gearbox oil leak
dale86 Dec 7, 2013
  1. dale86
    dale86 Member
    449
    15
    Hi all I have a 1.9tdi Quattro with a gearbox oil leak 6 speed its not serious but needs attending . I have steamed it all down and checked where it's source is and seems to be coming from the backend of the box where it looks like it can be split. Am I right in thinking this is the transfer box and is it gona be a hard job. If anyone can help It would be greatly appreciated and if it is a specialist job is their any additive you could suggest that can seal up leaks if it's gona be crazy exspensive thanks .
  2. Ian2012
    Ian2012 Active Member
    473
    29
    I had this once an old S6 that i had turned out to be a seal where the prop shaft goes into the box, additive wise the only one i use is Millers stop leak,
  3. dale86
    dale86 Member
    449
    15
    Thanks I'll give it a whirl cheers.
