quattro estate wheels
martyn s Apr 13, 2013
  1. martyn s
    martyn s New Member
    hi , ive just purchased a quattro sports estate, v6 3.0 its a 2002 car, i want to change the wheels, but am unsure what et and pcd they are, i thought 112 x 45 but after hunting high and low for wheels im even more confused, i reallt fancy a set of rs4 rep wheels on it.. grahpite grey perhaps.. but dont want to make the mistake of buying the wrong ones ! which is more important the et or the pcd ?
    thanks in advance
  2. Legacy87
    Legacy87 Member
    Im pretty sure the replica's would be mutli-fit and fit regardless of the cars offset, not sure what offset the car is however sorry, somebody will probably be along shortly to offer a hand.
  3. martyn s
    martyn s New Member
  4. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    I'd say the pcd was most important, and it needs to be 5x112 with a 57.1 centre bore as far as I remember. Spacers can be easily fitted if required. I seem to think most oem wheels are around 40-45 as a guide.
  5. quattrojames
    14,050
    578
    They'll fit perfectly. You want 5x112 (that's the PCD, you can get adapters, but why bother when 5x112 is such a common fitment). Standard ET is typically 43-45, but most people aim for ET30-35 depending on wheels width, desired look etc, and oem Audi 18's on our cars are 8J wide. Spot on.
  6. martyn s
    martyn s New Member
    Thanks, I will be purchasing wheels tommorrow :)
    what tyres can I fit ? i dont want to shake my teeth out, nothing too low profile...
  7. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    You'll need to fit 225/40-18 tyres which will keep the rolling circumference correct. It shouldn't give a harsh ride, I run 235/35-19's and the ride is still ok.
  8. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    626
    21
    235/40/18 are also good as you get a bit more rubber. Cost slightly more though
  9. crazy88
    4,939
    437
    235/40/18's are the correct size to give you the right circumference. 225 will be slightly lower circumference, but as long as they're all the same it should be fine. And as said, 225's are slightly cheaper.
    I run 235/40/18 on mine.
  10. Greeny233
    1,094
    385
    Yep my bad, 235/40-18's are closer to the rolling circumference of the original tyre size.
