quattro controls
Dlew Sep 7, 2012
  1. Dlew
    Dlew New Member
    My friend had a controller on his sti. It controlled the ratio of how much power went to the front or rear. Say 25% and 75%. Is there one out there for the Quattro?
  2. Tom_B
    Tom_B Member
    296
    20
    I think the B5 4wd system is mechanical and not controlled by an ecu. I am sure somebody will be along soon who knows much more...
  3. adamss24
    adamss24 Well-Known Member
    4,584
    407
    You can get a STASIS Motorsport tweaked rear diff which can alter the bias however it will still be 50-50% split in normal use but with more power going to the rear wheels when the wheels slip ! The Torsen rear diff is purelly mechanical system and apart from the EDS (cheap traction control system working as a limited slip diff with the aid of ABS + braking system) there's not much you can do to it !
  4. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Yeah I think its the S3's that you can have a Halex controller.
