Quattro and FWD suspension
sam4191 Jul 23, 2009
  1. sam4191
    sam4191 If In doubt, Flat out!
    417
    Just a quick one... been thinking... Is the suspension the same on Front wheel drive?
    Sam
  2. stapo69
    stapo69 All hail the mighty quattro!
    969
    Are you meaning are the fronts of the 4wd and fwd the same? I believe so. Same on the Passat B5 too.
  3. sam4191
    417
    hmm... well, thinking about it, the rears will be different. Are the springs the same al round though??
  4. Broken Byzan
    13,237
    465
    Springs and shocks same type/style on 2wd and 4wd, Completely different for both on rear sadly
  5. sam4191
    417
    Oh right. Thanks alot for that guys! Has cleared it up!
  6. aragorn
    18,539
    865
    Just to clarify Marks explanation:
    The front end is the same, obviously there will be spring and shock differences depending on the engines etc but we have S4 front shocks on our A4 and the springs would swap over too.
    The rear end is different though, as the Quattro has double wishbone rear suspension and the FWD cars have a torsion beam, so none of it would swap over.
