Quantum tuning Bristol
JayMc Jan 28, 2014
  1. JayMc
    JayMc Searching for 6th gear
    52
    9
    DPF Removal | Chip Tuning | ECU Remap - Bristol - Automotive Remapping
    Has anyone had any experience of these guys, or have any thoughts on their remaps as I'm looking into getting my 1.9tdi 130 a4 remapped, and came across a guy that works here, through my work. Seems to know his stuff and is mobile which is good. The bhp gain of 159 seems a little low but good torque figures of 380nm. Only other option I've been looking at is Shark performance but its a bit of a trek to the nearest dealer.
  2. MooLard
    MooLard Member
    229
    Blacksmoke remaps, it's a diy remap and makes about the same results. I did my car and am mighty pleased with it, excellent value for monies.
  3. JayMc
    52
    9
    I did read up on blacksmoke, but am a bit worried about something going wrong and bricking the ecu! It does seem very good value for money though.
  4. Gazwould
    Gazwould Well-Known Member
    4,702
    1,879
    380nm might upset the clutch by it slipping depending on clutch condition and how smooth the torque curve is on a new map.
    You can get maps with 360nm and 175 bhp to avoid this.
  5. MooLard
    MooLard Member
    229
    Agree that's part of the reason I went with that remap, not mega aggressive or maxed out torque of the components.
    You're right it is a worry bricking the ECU but I thought I would be ok as I took the recommended precautions of attaching a battery charger to the car, made a backup of the ECU and then flashed it with the new stuff.
    I found resetting all adaptations after and then driving until up to temperature got the most out of the remap too.
  6. JayMc
    52
    9
    I'm defiantly going to fit a new clutch, as mine is getting 'tired' so hopefully shouldn't' be a problem. Before I enquire does anyone know if Shark do a mobile service? I'm also going to look into what sort of job a diy blacksmoke map is and what leads/cables will do the job.
  7. Gazwould
    4,702
    1,879
    What's your tired clutch symptoms ?
  8. JayMc
    52
    9
    Car loaded up in 5th gear, accelerator flat out, the clutch slips slightly as the turbo spools up (2-2500rpm). 6th gear is fine.
  9. Gazwould
    4,702
    1,879
    Bingo !
    I had exactly the same and a reduced torque remap eliminated clutch slip.
    I put it on a dyno and the torque curve was smooth with a flat curve that held torque for longer.
  10. JayMc
    52
    9
    What map did you use?
  11. deano1978
    deano1978 different gear
    713
    80
    Mine is remapped by experttuning.co.uk and is very good remap.
    They run in team with quantum,who r the actual tuners,so i reccommend them :)
    JayMc likes this.
  12. Gazwould
    4,702
    1,879
    CCCTech , I think it's a tweaked Upsolute map.
