Qts replacement key.
Chriscooke Mar 10, 2013
  1. Chriscooke
    Chriscooke Clueless!
    484
    21
    My car only came with one key :( is their a cheapish way of getting a new one cut and coded or is it audi only :( I'm thinking of trying hickley valtone but any other options?
  2. TrisLC
    TrisLC Member
    334
    Hi mate, I had one replaced via vw for my mk4 golf. They provided the key and coding for 150 if I remember correctly but that was a few years ago now.
    Can you not buy a blank key, get it cut and programmed in via vagcom?
    Im sure ive seen keys for sale on eBay
    Tris
  3. griswold
    griswold Member
    346
    You need the code from the dash to code yourself and a blank transponder.
    Vagtacho can extract the pin code. I got a key cut from ebay via a photo and a blank transponder.
    Just need new fob with the same freq as yours.
    Might be worth getting a price from audi.
  4. griswold
    griswold Member
    346
  5. aragorn
    17,810
    679
    yeh you can do it pretty cheap if your prepared to do a bit of legwork and DIY.
    Get yourself a used fob, two or three button will work fine, ebay is your best bet here, you can get them for around 20quid if your patient. Alternatively, find someone breaking an A4!
    Blade cut to fit as mentioned above.
    Then you'll need vagtacho to pull the SKC from the cluster, and program the new transponder.
    I reused the immo transponder in the used fob when i did mine, it recoded just fine.
