Q7 Scan results
Gavin0478 Jan 23, 2014
  1. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 S-line owners group TDi
    524
    39
    Hi just ran my first scan on my recent Q7 to get these faults.
    Just after some advice before it gets sent back under warranty.
    Cheers.
    Mileage: 28210km/17528miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    11-Engine II -- Status: OK 0000
    31-Engine other -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    18-Aux. Heat -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: Malfunction 0010
    3D-Special Function -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    5C-Lane Maintain. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    69-Trailer -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
  2. Gavin0478
    524
    39
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
    Component: FBSAUDIC6 ELV H05 0130
    Revision: 00H05000 Serial number: 10602901641732
    Coding: 0000215
    Shop #: WSC 31414 790 00001
    VCID: 254797A9ECD74136C75-8070
    Subsystem 1 - Part No: 4F0 910 132 G
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 335 B
    Component: FBSAUDIC6 KSG H03 0020
    Subsystem 3 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H01 0053
    5 Faults Found:
    00190 - Driver's Door Handle Touch Sensor (G415)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01110111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 2
    Time Indication: 0
    00193 - Rear Right Door Handle Touch Sensor (G418)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 2
    Time Indication: 0
    00192 - Rear Left Door Handle Touch Sensor (G417)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 104
    Mileage: 27926 km
    Time Indication: 0
    Date: 2014.01.14
    Time: 06:01:43
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00111000
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 56
    Mileage: 24619 km
    Time Indication: 0
    Date: 2013.05.09
    Time: 14:16:00
    Freeze Frame:
    Fault Status: 00111011
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 143
    Mileage: 24490 km
    Time Indication: 0
    Date: 2013.04.20
    Time: 10:43:55
    Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
    Part No SW: 4L0 920 983 L HW: 4L0 920 983 L
    Component: KOMBIINSTR. H10 0209
    Revision: 00000000 Serial number: FLD40V38A
    Coding: 2F5663040D012600010400
    VCID: 3B7351D1BA53E7C6811-806E
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 1
    Mileage: 24382 km
    Time Indication: 0
    Date: 2010.04.16
    Time: 16:34:15
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 G
    Component: Heizgeraet H09 0140
    Revision: 0000000C Serial number: 00000009021078
    Coding: 0000001
    VCID: E0C946BD3375641E743-80B5
    2 Faults Found:
    01444 - Under-Voltage Shut-Off (Automatic)
    000 - - - Intermittent
    00664 - Fuel gauge
    002 - Lower Limit Exceeded
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
    Component: GW-BEM 5CAN-M H06 0047
    Revision: MB300033 Serial number: 3300M10718817C
    Coding: 00C303
    VCID: 3D775FC9A447E9F6BF5-8068
    Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
    Component: J367-BDM H07 0125
    1 Fault Found:
    03041 - Energy Management Active
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 53
    Reset counter: 152
    Mileage: 24596 km
    Time Indication: 0
    Date: 2013.05.07
    Time: 08:35:41
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 11.50 V
    Count: 11
  3. Gavin0478
    524
    39
    Address 34: Level Control Labels: None
    Part No SW: 4L0 910 553 H HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7870
    Revision: --H03001 Serial number: 15.1528-0123.2
    Coding: 0015520
    Shop #: WSC 10886 000 1048576
    VCID: 2F6B7581BE2B0B663D9-807A
    3 Faults Found:
    03004 - Load Level Button (E539)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Error Code: 156
    01577 - Turn-Off due to Over-Temp
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 6
    Fault Frequency: 11
    Reset counter: 168
    Mileage: 25019 km
    Time Indication: 0
    Date: 2013.05.12
    Time: 16:22:14
    Freeze Frame:
    Error Code: 68
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 168
    Mileage: 26926 km
    Time Indication: 0
    Date: 2013.09.10
    Time: 09:34:41
    Freeze Frame:
    Error Code: 13
    Address 3C: Lane Change Labels: None
    Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
    Component: J0769_SWA_MasterH01 0050
    Revision: 00H01000 Serial number: 6PZ 009 014-10
    Coding: 0011101
    VCID: 2E556885B921026E36F-807B
    Subsystem 1 - Part No: 4L0 910 568 C
    Component: J0770_SWA_Slave_H01 0050
    Subsystem 2 - Serial number: 6PZ 009 014-30
    Subsystem 3 - Serial number: 5F15.08.1000H010003C910101ÿ
    Subsystem 4 - Serial number: 910101ÿ
    1 Fault Found:
    01316 - ABS Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 146
    Mileage: 28080 km
    Time Indication: 0
    Date: 2014.01.19
    Time: 13:18:07
    Address 3D: Special Function Labels: 8K0-907-440.clb
    Part No SW: 8K0 907 440 HW: 8K0 907 440
    Component: STS H04 0040
    Revision: S0H04000 Serial number: 00000000022874
    Coding: 01010101000000000000000202
    VCID: EBD32191CAB33746D11-80BE
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 117
    Mileage: 27118 km
    Time Indication: 0
    Date: 2013.11.11
    Time: 11:18:26
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
    Component: TSG FA H12 0361
    Revision: Serial number: 0004000152712
    Coding: 011F56205E61440204
    VCID: 48993E1DFB85BC5E1C3-801D
    1 Fault Found:
    02126 - Central Locking Button; Exterior Door Handle
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 149
    Mileage: 27811 km
    Time Indication: 0
    Date: 2014.01.06
    Time: 16:07:53
  4. Gavin0478
    524
    39
    Address 47: Sound System (J525) Labels: None
    Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
    Component: BOSE G3 Q7 H03 0040
    Revision: CH003000 Serial number: 00000000004221
    VCID: 264590A551D14A2ECEF-8073
    1 Fault Found:
    03278 - Functionality Limited due to Missing Messages
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 32
    Reset counter: 152
    Mileage: 24533 km
    Time Indication: 0
    Date: 2013.04.25
    Time: 08:40:02
    Freeze Frame:
    Bin. Bits: 00000001
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
    Component: TSG BF H12 0361
    Revision: Serial number: 0004000153278
    VCID: 479B3D21F69BB326159-8012
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 84
    Mileage: 27118 km
    Time Indication: 0
    Date: 2013.10.29
    Time: 01:39:18
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
    Component: TSG HL H11 0361
    Revision: Serial number: 0004000148669
    Coding: 010E56204061230204
    VCID: 46853025F191AA2EEEF-8013
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 27
    Reset counter: 99
    Mileage: 27118 km
    Time Indication: 0
    Date: 2013.11.22
    Time: 10:42:11
    Address 69: Trailer (J345) Labels: 4E0-907-383.clb
    Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
    Component: Anhaenger H08 0070
    Revision: 2A001001 Serial number: 00000133435626
    Coding: 0100000100000000
    VCID: 316F73F9681F1D962BD-8064
    2 Faults Found:
    02562 - Trailer; Brake Lamps
    010 - Open or Short to Plus - MIL ON
    Freeze Frame:
    Fault Status: 11101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 26994 km
    Time Indication: 0
    Date: 2013.09.20
    Time: 12:14:12
    02563 - Trailer; Right Tail Lamps (M61)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 26994 km
    Time Indication: 0
    Date: 2013.09.20
    Time: 12:14:13
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H11 0361
    Revision: Serial number: 0004000148624
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 70
    Reset counter: 112
    Mileage: 27118 km
    Time Indication: 0
    Date: 2013.11.01
    Time: 05:22:18
  5. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,059
    761
    has the battery ever gone Dead?
    clear all the faults, take for a quick drive and re scan.
    Trups
  6. Gavin0478
    524
    39
    The battery was replaced under warranty before my ownership.
    Will re scan after a good run tomorrow but enabled battery meter and its showing 50%!!!
  7. t8ups
    2,059
    761
    they are codes from a battery been dead so more than likely didnt clear faults. usuall practice if it was replaced by Audi.
    its the small things they miss out on.
