Q7 3.0 TDI Starting Problem
zed Apr 1, 2011
  1. zed
    zed New Member
    My Q7 has a problem. From cold, it takes a good 4 or 5 seconds of cranking to start, and then it kind of coughs once and starts up.
    If I then drive it a mile or two and switch off before it has achieved full operating temperature, it will re-start cleanly, but will still crank for 4 seconds or so.
    However, if I drive it until it's at full operating temperature, and stop for fuel or a short stop at a shop and try to start it, it will crank forever without starting. I can get it started every time, but it takes 4 or 5 attempts of cranking for 7 or 8 seconds at a time, then it will fire cleanly.
    This issue is consistent in that I can make the problem occur by driving until full temperature is reached, then park up for two minutes, and when I try to start the engine again I have to crank it over 4 or 5 times for 7 or 8 seconds each time before it fires and starts up cleanly.
    The issue will only happen once per day, so any subsequent starts the same day after the above issue will start first time, but still takes around 4 seconds of cranking.
    Otherwise, the car runs fine once it's started.
    The fuel filter has been changed, and it's a new battery too.
    I have VCDS and no errors are reported.
    Any ideas?
    Thanks!
  2. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 S-line owners group TDi
    524
    39
    as a silly answer id say possibly a temp sensor is not working correctly so doesnt know whether to use glow plugs and hot/cold start maps.
  3. singh4406
    singh4406 New Member
    hey bud im having the same problem did u get yours solve
