Q: S3 Brake Upgrade Issue - Searched for 3 days!
KemiksiZ Jan 23, 2014
  1. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
    I'm begging for a few days in the forum bu no one hold my hand, except Jhonny :)
    Now I2m crawling the web, as much as I have time besides working, I took a great mile, now its where I'm:
    My car is 1.6 FSI, 2006 (facelifted), my s3 brakces and carriers are from 2007 S3.
    I have the caliper right carriers BUT I do not have the f$cking hub?/axis holder/what the hell of its name! They said that my thing is small to mount new s3 caliper carriers. Check the picture please; [​IMG]
    Now, what is the name of the marked thing & the part number for my Audi a3? And AS far as I investigated, asked & learned; my 'thnig' is not big enough to match the new caliper carriers below. This carriers have nowhere to mount on my current setup right now:
    So at that point, what should I do?
    Are they these ones? Org AUDI A3 8P Achsschenkel Radnabe Radlager vorne rechts | eBay
  2. NHN
    29,284
    1,695
    Known commonly as a hub, although vag may have a fancy name for it, not the cheapest item afaik, its annoying as some fit & some don't.
  3. KemiksiZ
    570
    142
    43
  4. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Probably something to do with the 50mm and 55mm struts? Smaller struts the smaller the hub? And I assume yours has the 50mm struts?
  5. KemiksiZ
    570
    142
    43
    okay, new word 'strut', made me more confused! :))
    If its the suspension leg kinda thing, yes. Mine is thinner. (smaller is not the rgiht word for the struts I guess) My caliper carrier matching thing is small :) Could you check the ebay links Chris, are these what I'm looking for? Any idea?
    I think this is it: AUDI A3 SPORTSBACK Radnabe vorn links - 1K0407255AA - Bj 2012 | eBay
  6. KemiksiZ
    570
    142
    43
    I think this causes everything? The mechanic says, I need the hub which can accept 21mm Bolts. My current ones are smaller than 21mm. Can you confirm that?
  7. chris.vincent3
    604
    34
    Yeah a "suspension leg" As for the eBay links I am not sure, but I'd imagine as long as they're the 55mm "suspension leg" hugs then that is what you're after, however, don't forget you'll need 55mm "suspension legs" if you're changing the hubs. Possibly the springs also (not sure).
    There was a thread containing all the vehicles that had 50mm and 55mm struts, I think it was just the 1.6s that had the 50mm struts, but not sure, you'll have to do a search.
  8. KemiksiZ
    570
    142
    43
    Am I changing the hub, by reviewing my case? :)
    I guess I'm but, cant be sure :s And what is the correct hub part no? There are a lot of part no's came accress :s
    Yes, I confirmed, 1.6fsi's has 50mm sturts instead of 55mm. Now there will be another thread what if we use 50mm struts with 55mm hub? so risky? I'll ask later :))
  9. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    OK!
    As I've told you on PM, in order to be able to install the S3 brakes you also need the right carriers. The ones for 312mm disks won't fit.
    Since your engine is the 1.6 one, you have even more trouble. Your current front carriers are built in the hub. You cannot replace them with the S3 ones.
    If you still want the big brakes (but I honestly don't know why, since the engine is not that powerful), you have to open your pockets, wallet, bank account wide.
    You need new front hubs, new struts, new springs (not sure about these though), carriers, maybe new bearings.
    For the hubs, you can look for ones from 2.0 TDI, 2.0 TFSI, 1.8 TFSI. Not sure but I think that also the cars with the 1.4 petrol engines also have the good hubs for you.
    1.6, 2.0 petrol and 1.9 TDI have the wrong kind of hub.
    When I say you can look for cars with those engines, I mean not only Audi A3 but also Golf 5/6, Skoda Octavia II and Seat Leon 1P. 2WD not 4WD.
    Search on ebay or at the breakers, if there are any in Turkey.
    If/when you have the parts and you are ready for the upgrade, I would also recommend new brake lines.
    Expensive and kinda useless upgrade for you IMHO.
  10. KemiksiZ
    570
    142
    43
    Yes, I'm all agreed and now a master :)) about what should I do after now EXCEPT i think I have the rgiht carriers wtih bolted on the calipers, isnt it a carrier in the picture?
    And what about re-drilling the current carrier bolts hugs, after welding it completely as no-hole at all? Is it so dangereous?
  11. KemiksiZ
    570
    142
    43
  12. crunchie
    crunchie Active Member
    880
    77
    Tell me you're joking!! It's your brakes for goodness sake!!!!
    Do you not have MOT's in Turkey?
    Sounds highly dangerous to me.
    Its obvious they are not designed for your car.
    Why do you need 345mm brakes on a 1.6 anyway??
    kanecullen89 and sliced like this.
  13. KemiksiZ
    570
    142
    43
    No, no, I wont do that, FOR SURE!
    Just read on the internet, some guy dhave done. And I just wondered about :)
    Just cosmetic mate, 19 rims need some bigger inside :)
  14. Johnny Bravo
    898
    69
  15. crunchie
    880
    77
    As someone has said before, it will involve the whole hub/damper assembly.
    Possibly even the spring and even then your drive shafts might not fit?
    Sounds like a big headache to me. Is there no other route to go down? AP set-up etc?
  16. KemiksiZ
    570
    142
    43
  17. Johnny Bravo
    898
    69
    You like to torture yourself...
    You could also look for a bigger engine and gearbox. That would be a proper job!
  18. KemiksiZ
    570
    142
    43
    Dont bother mate, I have an S4 with an ADEQUATE big engine ;)
    A3 is my project car, exterior project for sure, 1 liter gas is 3$ here, so I need a daily drive :)
    I'll pass on your Audi if it needs :p
  19. Johnny Bravo
    898
    69
    I saw the prices of fuel in Istanbul when I was there last October. I don't understand though how come, despite the huge prices, there are soooooo many cars on the road. You can get anywhere faster by foot.
  20. KemiksiZ
    570
    142
    43
    I bought the HUB today, I'll post pictures if I wont be dead tomorrow :p :))
    I'm very excited about the result, i did not see it yet but the hub was a direct fit, they used an adaptor for the 50mm ==> 55mm hub, so its perfectly safe and fine.. So i did not have to change the suspension legs-struts, springs, axles or anything except the hub. I paid 60 GBP for the 2 used but very well condition hubs. I'm going to take back my hubs in order to use it if I sell the car in the future..
    I'll see the result in a few hours, yay! :)
    crunchie likes this.
  21. KemiksiZ
    570
    142
    43
    HAPPY ENDING! :)
