put egr blank in and not getting warning light?
southylad Dec 21, 2012
  1. southylad
    southylad Active Member
    544
    as title says i just installed my egr blank plate , i expected to get a warning light up on dash to warn its not workig but nothing?
    i put the blank plate inbetween the thinner silver pipe and the egr on right hand side is this correct?
    any ideas why the dash ight has not come on as i have the car booked in for remap and egr light and software mapped out but its not on? any advice would be great.
    ok the pics is on its side so pipe i put it on is at the top of pic.
  2. A_C4mby
    A_C4mby Member
    51
    When i was trying to find a stutter on my BKD, I blocked the hose feeding the EGR valve using a golf tee. The car drove so much smoother, and no fault came until a coolish damp morning.
  3. southylad
    544
    which one the little black hose is that a vacume hose does that operate a diafram to open and close the egr is it as simple as takeing that of and blanking that? the car seems to idle a lot smoother already yeh
  4. A_C4mby
    A_C4mby Member
    51
    Yep, it's just a vacuum pipe connected to a diaphragm. A spring holds the valve shut, then the vacuum opens the valve.
  5. nluk100
    nluk100 Well-Known Member
    1,093
    206
    It might take a while for it to appear - too a couple of days on my old diesel.
  6. southylad
    544
    Management light now on came on this morning
  7. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Southylad, pleased to report no clutch slip after the map and damn it goes some now! Sorry wrong thread being lazzzzzyyyyy
  8. southylad
    544
    Hey glad to here that mate bet it was a good drive home eh , can't wait to get mine done now mate bet it puts a smile on your face every time you touch the peddle eh
  9. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Southylad, would you be able to mark on the photo where to fit the blanking plate? Looks like this will be my next mod.
  10. southylad
    544
    Can't seem to do it in editing mate but will try and explain for a start the pic has been flipped so the top is in fact the right hand side so you see the silver pipe with the oval flange and 2 hex bolts holding it at top of pic you just undo the 2 hex bolts ease the flange away from the egr body and slip you blank in and replace the hex bolts it is an easy job the plates are only couple of quid of eBay then you have to have the egr mapped out if you don't want the eng man light on all the time
  11. SAiLO
    1,078
    62
    Thanks mate!
    That was my guess but wanted a confirmation.
    I'm gonna go for this part:
    028 131 547 B which has a small hole drilled that prevents the EGR light coming on.
  12. southylad
    544
    Yeh I looked at them aswel mate
  13. myke
    myke Member VCDS Map User
    97
    The light will and did come on after the EGR delete mod untill the Map is changed.
