Put a new battery in My key Now it wont work !
ChuckH Mar 7, 2009
  1. ChuckH
    ChuckH Member
    159
    Put a new battery in My key Now it wont work ! Car is an A4 Avant 2006 B7 chassis I fitted a new battery Then followed the handbook IE Open the car with the key. Then press the unlock button Then put the key in the ignition switch and turn on Then it should work But it doesent ! Any ideas please ?? TIA.................
  2. Pert_A4
    Pert_A4 New Member
    Not sure if this will help but when i replaced the battery all i did was unlock the car with the key then start the engine. after that it managed to work. Hope it works for you.
  3. S3-Andy
    S3-Andy Member
    204
    i would check your new battery first!
    your key may have lost its memory this may help
    [FONT='Verdana','sans-serif']Re: Programming Keys[/FONT]
    [FONT='Verdana','sans-serif']Programming[/FONT][FONT='Verdana','sans-serif']
    When
    [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] added or replace
    system malfunction
    How
    NOTE: max of 4 keys can be programmed (one at a time).
    memory positions of existing keys can be identified using diagnostic equipment
    If Diagnostic equipment available:
    locate vacant memory position for new [/FONT]
    locate memory position for [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] to be replaced
    carry out programming procedure for this [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] only
    if diagnostic equipment not available: Obtain and reprogram all keys
    NOTE: Existing [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] memory positions will be overwritten[/FONT][FONT='Verdana','sans-serif']
    switch ignition ON, Use [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] not fitted with [/FONT][FONT='Verdana','sans-serif']remote[/FONT][FONT='Verdana','sans-serif'] control
    Manually lock driver's door using [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'].
    Complete the following within 30 seconds:
    Within 5 seconds press unlock button on first [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] once (programs memory positions 1)
    Indicator lamps flash once to indicate signal received.
    Wait 5 seconds.
    Press unlock button once to confirm programming.
    Vehicle unlocks. Program mode deactivated.
    Switch ignition OFF. Remove [/FONT]
    [FONT='Verdana','sans-serif']Key[/FONT][FONT='Verdana','sans-serif'].
    To program remaining keys into memory positions 2,3 and 4. Carry out the complete procedure below for each [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif']:
    Switch ignition ON. Use the [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] not fitted with [/FONT][FONT='Verdana','sans-serif']remote[/FONT][FONT='Verdana','sans-serif'] control.
    Within 5 seconds press unlock button at 1 second intervals, as follows:
    Twice for memory position 2 (2nd [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif']).
    Three times for memory position 3 (3rd [/FONT]
    Four times for memory position 4 (4th [/FONT]
    Indicator lamps flash once every time unlock button is pressed to indicate signal is received,
    Wait 5 seconds.
    Press Unlock button once to confirm programming.
    Vehicle unlocks. Programming mode deactivated.
    Switch ignition OFF, Remove [/FONT]
    NOTE: Ignition MUST be switched OFF between each [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] programming procedure.[/FONT][FONT='Verdana','sans-serif']
    Memory erase procedure
    When
    Lost [/FONT]
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] fitted with [/FONT][FONT='Verdana','sans-serif']remote[/FONT][FONT='Verdana','sans-serif'] control
    Incorrect number of keys supplied with vehicle.
    Switch ignition ON.
    Press unlock button 5 times, at one second intervals.
    Indicator Lamp flash once every time unlock button is pressed, to indicate signal is received.
    Wait 6 seconds.
    Press unlock button once (to confirm erase procedure)
    [FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] from ignition.
    [/FONT]
    [FONT='Verdana','sans-serif']Remote[/FONT][FONT='Verdana','sans-serif'] control should no longer operate system.
    Obtain and program all keys.[/FONT]
  4. S3-Andy
    S3-Andy Member
    204
    dont know whats goin on with that last post i just coppied and pasted a word doc and came with all that added font ****
    anyway if u want drop me a pm with u email and ill send it ur way
  5. dantdi
    dantdi ...
    521
    May i ask why did u need new battery?
  6. consilio
    consilio Up the owls!
    666
    Paste it into notepad, then copy and paste it into ASN - this will get rid of the formatting markup.
  7. S3-Andy
    S3-Andy Member
    204
    nice one will give it a try
  8. S3-Andy
    S3-Andy Member
    204
    ________________________________________
    Programming
    When
    key added or replace
    system malfunction
    How
    locate vacant memory position for new key
    locate memory position for key to be replaced
    carry out programming procedure for this key only
    NOTE: Existing key memory positions will be overwritten
    switch ignition ON, Use key not fitted with remote control
    Manually lock driver's door using key.
    Within 5 seconds press unlock button on first key once (programs memory positions 1)
    Wait 5 seconds.
    Switch ignition OFF. Remove Key.
    To program remaining keys into memory positions 2,3 and 4. Carry out the complete procedure below for each key:
    Switch ignition ON. Use the key not fitted with remote control.
    Twice for memory position 2 (2nd key).
    Three times for memory position 3 (3rd key)
    Four times for memory position 4 (4th key)
    Wait 5 seconds.
    Switch ignition OFF, Remove key.
    NOTE: Ignition MUST be switched OFF between each key programming procedure.
    When
    Lost key fitted with remote control
    Switch ignition ON.
    Wait 6 seconds.
    Switch ignition OFF. Remove key from ignition.
    Remote control should no longer operate system.
  9. S3-Andy
    S3-Andy Member
    204
    hope this helps
    thanks consilio :thumbsup:
  10. ChuckH
    ChuckH Member
    159
    Thanks Andy ! Unfortunatly it hasent worked I put the Blank key (The slim one that normaly never gets used) into the ignition and switched on Then locked the door with the key Iwas trying to program Then within the 5 seconds pressed the unlock button But the indicators did not flash to aknowledge the signal ????
  11. ChuckH
    ChuckH Member
    159
    Because the key would not remotely lock or unlock the car Mate..
  12. S3-Andy
    S3-Andy Member
    204
    ive never tried it yet i need to get me new spare cut first, i came across it on this site and saved it for when i get round to doing mine, could there be a problem with your remote?? or does anyone know if this procedure is just wrong??
  13. ChuckH
    ChuckH Member
    159
    Andy there is a small LED on the key which flashes when any of the function buttons are pressed The one on the faulty key flashes just the same as the one My wife has . But I just cant get it to lock or unlock the doors since fitting the new battery Ive changed the battery again in case I had fitted a faulty one But as yet No good ! Audi want £60 to do the job !
    Im wondering if investing in Vag Com So I can sort iot out as Id rather put 60 quid towards that than pay it to Audi for a 2 minute job !
    Genuinly appreciate Your help ........................................
  14. S3-Andy
    S3-Andy Member
    204
    just found this mate from another thread, worth a try
    Right everyone cheers for all your replys , was just about to go to the stealers when i thought id have a quick look through my manual, it tells you how to synchronize the key fob! It was easy press unlock/lock on the fob then within 30 secs put the key in the lock and either unlock or lock the car and it will re-synchrozine its self!
    Cant believe the stealer wanted £80 to do that! Robbing Bast**ds
    Still got to fork out £180 for a spare key though
    Cheeers for all the info again
  15. S3-Andy
    S3-Andy Member
    204
    just checked the manual and yhe above procedure should re-sync it
  16. ChuckH
    ChuckH Member
    159
    Just tried it and it doesent work !
    But I have a plan A cunning plan ! It involves s small quantity of unleaded and a Swan Vesta .............................................................
  17. S3-Andy
    S3-Andy Member
    204
    no body local got vag-com??
    better than parting money with the stealers!
    keep me posted mate as i say i am yet to re-program my spare
  18. dantdi
    dantdi ...
    521
    Lol sorry im being a dum ass again! Didnt read it right, thought u meant the car battery! :blush:
