Pulling left and right, any ideas?
scottshere Nov 30, 2011
  1. scottshere
    scottshere Member
    369
    Just looking for some ideas as to why it would be pulling left and right
    When i accelerate it pulls right
    When i let off it pulls back left
    The left wheel does seem to be the one that spins easy too, not sure if this has anything to do with it
    Going to get it checked at a garage, just need an idea before i go
  2. moggie93
    moggie93 Member
    96
    Check the easy things first .. Like tyres pressures , do both front wheels have the same tread pattern, then it's onto wheel alignment and checking suspension components...
    Hth M
  3. Mike B
    Mike B Well-Known Member
    1,101
    40
    If you are saying that the left wheel spins easily but the right doesnt that one may have a caliper which is sticking and the brakes stuck on so it would pull to the right.Easy way to check is to carefully feel if the right wheel is getting hot and the left not so
  4. scottshere
    scottshere Member
    369
    Thanks guys. Tread pattern is the same and pressure is the same too. I do need some new brakes, so try that and see how it goes.
    Have also been told it could be wishbone bushes
  5. Mike B
    1,101
    40
    If you do the brakes you will find out if the pistons are moving freely and if the r/h pads are more worn
  6. T0m
    T0m Active Member
    516
    26
    tracking fella this can also have an impact
  7. scottshere
    scottshere Member
    369
    Getting 4 wheel tracked after i have the new disks and pads fitted. It does seem a bit jumpy to on the backend when going over pot holes/bumps
  8. scottshere
    scottshere Member
    369
    When i say jumpy, i mean it skips out a bit
  9. macpdm
    macpdm Member
    403
    I had this once when I bought a set of alloys which I found out after had the wrong offset. Really messed up the steering
  10. scottshere
    scottshere Member
    369
    Standard sport alloys, just hope they aint bent :-S
  11. simon.m
    simon.m Active Member
    2,747
    you would no it if they was bent mate id say tracking too also dont no how long you have ownd the car but i changed my wheels from 205/55/16 to 235/45/17 and it took a few weeks for me to get used to them being that bit wider car was grabing every paert of the road it could so any small dip in the rd the car would pull over that way if that makes seens
  12. abyrne153
    abyrne153 Member
    116
    worn track rod end ? I'd guess the lhs. Under acceleration the wheel toes in. Lift off the wheel toes out. Had exactly the same thing recently on a Renault van.
  13. marktdisport
    marktdisport Active Member
    1,195
    15
    mine seems to have a little play in the steering rack only on the n/s and sometimes i get a very similar affect of what you describe m8 just jack the front up one side at a time and give them a shake mines only slight but very noticeable its there
  14. scottshere
    scottshere Member
    369
    Cheers all
    going to have a butchers at it on my day off next week.
    (tonight i just clipped some metal posts that were protecting a lamp post in a car park - Sooooo gutted, marked the fin on passenger door. Why do they have them sticking so far out!)
  15. Royh1179
    Royh1179 Member
    70
    Simon.M i agree with you mate on the 235's thats what ive got does take some getting used to feels like cars taking over lol ive gota do track rod end today also i suppose its the price we pay for wide wheels lol
  16. scottshere
    scottshere Member
    369
    Just had new disks and pads all round (last monday)
    Seems to be better, but not really taken it for a run on a decent road yet (one that hasnt been dug up 10,000 times)
    Trip to birmingham tomorrow, so will see then...
  17. Royh1179
    Royh1179 Member
    70
    your kinda heading in same direction as ill be on fri then im heading of to walsall west mids, thats unless the snow falls faster than it is allready and messing up my plans
  18. marktdisport
    1,195
    15
    my neck of the woods lol
  19. Royh1179
    Royh1179 Member
    70
    was mine up untill 5 yrs ago now live in lincolnshire lol jus means regular drives bk to mids to see fam n friends lol
  20. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    any updates?
  21. scottshere
    scottshere Member
    369
    Update: Still the same... :keule:
    So changing the disks and pads has not fixed it, next is new tyres and then the tracking
    Mechanic says he cannot see any problems when he changed the disks
    I do have a slight vibration or maybe miss fire at 1500 to 2000 rpm
    Also at 75/80 mph if i accelerate hard
    Clutch is getting ready for changing, so could be dual mass, could be engine mount
    Got a bit of an oil leak around the EGR and believe it to be the crank case breather
    Temp never gets about 70 ish and have changed the sensor, so thermostat as soon as i get the chance
    I guess its going to be a bit of trial and error on each thing and keep chipping away at them till its all sorted
    Ive got a bit of a long road ahead... :whistle2:
  22. marktdisport
    1,195
    15
    mine discovered a vibration on hard acceleration since remap but new DMF has cured it now.....
