Prop Shaft, Anyone Know what tool is used to disconect it from the transfer box??????
Dan s3 audi Jun 26, 2012
  1. Dan s3 audi
    Dan s3 audi Member
    164
    As title says, this is the last thing holding me back from takeing my engine out.
  2. Have you taken out the 3 10mm double hex bolts?
  3. Dan s3 audi
    Dan s3 audi Member
    164
    Dont i need a torx female socket for them but not the start ones the m classed ones?
  4. Ronin225
    Ronin225 SEAT owner
    81
    I think i managed to undo them with just a socket
  5. Yeah just use a standard double hex 10mm
  6. <tuffty/>
    21,805
    4,174
    10mm socket is what I use on a long 1/2" extension... you also need to use something (large screwdriver or similar) to stop the prop turning while you do it... 3 x bolts as previously mentioned
  7. Dan s3 audi
    Dan s3 audi Member
    164
  8. S3SYD
    S3SYD Member
    158
    Thought it was a female torx drive socket????
    Think it can be done with a 10mm multi point socket but the proper tool is a torx......
  9. No it's not a Torx
  10. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    10mm 12 point socket without a doubt. Do it from above with the tip removed, its a doddle.
    I used a 3/8" ratchet and moved the car back and forward to turn the prop and get access.
  11. S3SYD
    S3SYD Member
    158
    I'm wrong then
    Been ages since i worked on mines
    Multi point socket it is
