Project "Pinky", couple of teething problems.??
Oranoco Apr 3, 2011
  1. Oranoco
    Oranoco Well-Known Member
    3,862
    381
    Project Pinky is finally alive and in use. Couple of really annoying teething problems which I could do with some suggestions on.
    1. Speed isn't working.
    2. Bottom Rad hose keeps popping free and leaking.
    Only other issues are the alignment is out and it needs some dash bulbs.
    Mate has been busy though and he's already got a front mount on it.
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    1. Use Vagcom to check whether it's the instrument cluster or the crank speed sensor.
    2. Use a better hose clip!
  3. aragorn
    18,135
    764
    the rad hoses use a plastic fitting with a wire retainer, either the wire is missing, or your not pushing it on far enough to lock the wire into the groove on the rad.
    Speedo drive is on the gearbox, near/above the nearside driveshaft flange.
  4. Oranoco
    3,862
    381
    Cheers, water hose sorted, small drop of silicone lube and the hose went on far enough. Bit too much crud on the ting so the locking wire wasn't going into it's proper position.
    Speedo drive must have got damaged when we did the engine swap.
    Sounds really sweet and healthy though :)
