project ASBO audi a3
jonno123 Jan 12, 2013
  1. jonno123
    jonno123 Member
    99
    Welcome to my Project
    audi a3 1.8t 20v
    only mods it has so far are a set of kw coilovers
    and a s3 rear bumper ( but i dont like it as it dont fit to well)
    so this is how i got the car
    i then fitted fmic and relocated the dump valve
  2. jonno123
    jonno123 Member
    99
    next job i fitted a piper exhaust system
  3. jonno123
    jonno123 Member
    99
    next i fitted a techedge wideband
    and then come along was my emerald k6 aftermarket ecu with 3 maps with plug and play plug :)
  4. jonno123
    jonno123 Member
    99
    as it sits now its running 190 bhp and 240 lbft , on a worn out k03 turbo
    next week should see my gt28 71r arrive :)
  5. jonno123
    jonno123 Member
    99
    how it sits now
  6. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    I like this build,look forward to seeing it progress
  7. Dani_B19
    9,360
    399
    Nice. Why have you swap the oem management over though?
  8. jonno123
    jonno123 Member
    99
    reason 1 , i dont need a maf , so i just use tps vs map
    reason 2 , i can do alot more with after market ecu such as
    Adaptive Lambda control: Self learning fuelling capabilit
    Adjustable speed and load sites
    Closed Loop EGT control
    Tailor boost curves
    Map switching
    Diffrent boost in diffrent gears
    i can change every single setting in the ecu , i dont have to pay some one to plug vag com in to see for any problems , or change settings
    it really dont cost that much to do , and its easy to use and understand and best of all its plug and play :)
  9. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    ALL of that can be done on ME7.
  10. Prawn
    11,637
    3,627
    Yes, well done Jardo. This car doesn't have me7, and it'd cost just as much to convert to me7 as it would emerald, I know which I'd choose.
    Looks cool mate, nice to see a different approach. Had you got any more details about this plug and play emerald setup? Does it retain the stock ecu to run the clocks and things? Is it genuine standalone? Or more of a piggyback affair?
  11. Westy
    Westy Well-Known Member
    17,443
    1,105
    This is interesting stuff. I used to run an emerald ECU on my old Lotus Elise so I'm interested to see how this turns out on an 8L.
  12. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,495
    210
    I've seen an emerald ecu on a blue lotus x reg think it was that was more of a piggy back ecu for the 1.8 turbo engine fitted. Retaining standard clocks ect.
    Looks interesting build , something different.
    Sean
  13. Westy
    17,443
    1,105
    The lotus ecus were dreadful and a piggy back still didn't give many tuning advances. They needed an emerald and some decent cam pulleys to fine tune them.
  14. jonno123
    jonno123 Member
    99
  15. jonno123
    jonno123 Member
    99
    its fully standalone , you remove the bosh ecu and have an adaptor that plugs to your std loom and plugs into the emerald , every thing works except the mpg thing on the dash and one little thing controlling the dbw for idle , there finishing off the software for that so , i just fitted an idle screw
    also atm they only have a plug and play loom for an agu with 3-pin coils ndbw
  16. jonno123
    jonno123 Member
    99
    there 100 % standalone , emerald ecu works with can bus system so all the clocks work in a lotus
  17. Prawn
    11,637
    3,627
    That sounds very cool indeed mate! I have an AGU with 3 pin coils so that's not an issue.
    Is emerald able to do anything like launch control or similar? I take it it controls boost via the standard N75? Does it have knock control as well like the stock ECU? What sort of cost are you talking for the ECU and plug+play loom all in?
    Sorry for all the questions! It's nice to see someone doing something a bit different for a change!
  18. jonno123
    jonno123 Member
    99
    yes use is the stock n75 , you can have launch control , if you use the map switch and push button so you use one map with a low soft cut and hard hard cut rev limit , and then you only have too maps , thats one way to do it , knock control should be ready soon just waiting for the new software to be realesed , lots more feautures coming too , and should be free , like tc , dbw , turbo timer
    money wise
    ecu cost 595 + vat
    plug and play plug cost 120 +vat
    and map sensor cost 60 + vat
    so it something like 780 plus the vat and you get discount if you say your on here i think like 5% off
  19. stevegti2
    stevegti2 Member
    229
    13
    ive got a emerald k6 for my suzuki swift the new ones have a feature for traction control aswell and a few other odds and sods there a great ecu plus being british advice is always there and dave walker is a legend i see why you changed it
  20. Prawn
    11,637
    3,627
    I was going to ask if it was still Dave Walker behind it all! He's a bit of a legend in the Mini circles :)
  21. jonno123
    jonno123 Member
    99
    yes dave still ownes emerald , but he dont map on the rolling road any more , i do :) , dave runs the engine dyno
  22. Prawn
    11,637
    3,627
    Aaaaaaaaaaaaaaaaah, and suddenly it all makes sense :p
    Good for you man. Nice to see something other than the usual 'what air filter should I use' thread!
    VAG-Slag likes this.
  23. badger5
    9,575
    2,038
    but not me3.x
  24. badger5
    9,575
    2,038
    mk2 golf here now, on GT35 was on MBE, we have now wired in Emerald.... Not the latest version however.
    the TT I race against runs Emerald.. Works fine. Nice features.. I still like my DTA's however.. The new K6 has better features over its predecessors so I need to review their specs.. They keep developing them.
  25. SoljahofSensi
    SoljahofSensi Member
    93
    Hey Steve did u have a older swift gti (was it wide body turbo?) and were u on the old ukswift forum?
  26. jonno123
    jonno123 Member
    99
    small updates spent some pennies ill let pics do the talking
    after a good clean
  27. Paradox1
    1,833
    88
    this has to be one of the Nices 8L's on the forum!.
    What size rubber you running? they look chunky!
  28. Prawn
    11,637
    3,627
    it's not fair. I WANT A RED ONE!!!!!
  29. jonno123
    jonno123 Member
    99
    thanks :) its not bad for its age and original paint so win :)
    205 55 16
  30. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Cool B)
  31. stevegti2
    stevegti2 Member
    229
    13
    @solja of sensi yes thats me mate the gti in my name refers to swifts not silly golfs :rock: and as for dave walker last i heard his health took a turn for the worse but a mate went up there for a ecu and said he was on the up wich is good :)
  32. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Nice car and mods. Keep it up!! Looks pretty awesome in red.
    Seen this beast in PPC...
  33. jonno123
    jonno123 Member
    99
    yes dave health did go down but he is alot better now
    he running the engine dyno will i run the rolling road
  34. jonno123
    jonno123 Member
    99
    so i have been getting lots of bits together so i could fit my gt28 71r here is a few pics
    new exhaust mani
  35. jonno123
    jonno123 Member
    99
    a random one of my dog looking cool
  36. jonno123
    jonno123 Member
    99
  37. stevegti2
    stevegti2 Member
    229
    13
    crazy laughing...lol
  38. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    nice bangs ;)
  39. AARON77
    AARON77 Well-Known Member
    1,324
    31
    isnt this Wendy's old car???
  40. jonno123
    jonno123 Member
    99
    yes it is :)
    also just give richard his corrado back after doing some work to it
    hope to see you at some of your events Aaron
