Problems with "Door Open" display on dash
CornishA3 Aug 1, 2007
  1. CornishA3
    CornishA3 New Member
    Hi , i was wondering if anyone can help , i own a 2001 Audi A3 tdi sport and have recently been experiencing a problem with my dash display showing up that my drivers door is open when it isnt ...the only way i can get it to go out is by constently opening and closing the door until it goes out....any ideas ? ....if it wasnt for the fact that the interior lights come on when the door open display is showing i could probably live with it ...! HELP!!!!!!!!!!!!!!!!!!!!!!!!!:scared2:
  2. aidank1981
    aidank1981 Member
    252
    its really commen mate, loads on here! its the micro switch in the lock unit, you can clean it with contact cleaner etc but it'll eventually die! ive just bought a new one from audi for 39.97+vat part no 8L2837016B (DRIVER SIDE S3 MIND) surely a small repair but a bit job stripping to door down....
  3. Yeah I've got this problem too on my 1.9 TDi (2001).
  4. buckas
    buckas Member
    749
    it's occurs most frequent when the car has been sitting a while with the sun on it i've found
  5. mordz
    mordz Audi S3 (2000)
    305
    yeh mine does the same, park in the shade and its fine
  6. rickparmar
    rickparmar Active Member
    2,323
    14
    so true
    i cant justify spending 40+ just to fix it, i can live with it, just switch interior lights off, and as soon as you sit in press the dis controller so it shows somthing else :)
    but i heard the alarm isnt fully armed or somthing
  7. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    Same issue here. I find that a little WD40 sprayed into lock works for a few days, otherwise slamming the door several times seems to sort it, especially after a mile or so of driving.
    Riks suggestion is equally as good.
  8. garratt83
    garratt83 Member
    244
    About the alarm, from what i've heard if you lock the door with the door problem the red lights don't flash on the doors and I think the internal sensors are disabled
    Someone correct me if I'm wrong?
  9. nick-barnes07
    nick-barnes07 Member
    554
    i find opening the door wide open and slamming it once makes it go of , never seems to go of when i just open and slam the door , i have got to fully open it
  10. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Glad other people are having this issue as i thought it was just me.
    I have noticed the sun thing too does the micro switch overheat or something??
    I have just got used to shutting the door firmly whenever i get in or out of the car and also making sure the red lights are flashing when i leave the car.
  11. steebo888
    steebo888 Member
    218
    Yep i have this problem as well.
    I re aligned the door a few weeks ago and it does not do it as often now.
    Again i just turn the interior light off and press the dis button go get rid of the door open display.
    Just gonna live with it
  12. batwad
    batwad Member
    864
    Yes, it's a stunningly common problem. I had mine done by Audi (under warranty fortunately) last month. The dealer confirmed that the alarm does not arm if the car thinks one of the doors is open, so you're compromising the security of your car by not fixing it.
    Mind you, the A3's alarm is pretty feeble...
  13. CornishA3
    thanks for all your posts guys ...well helpfull apart from the cure !!!! ...does anyone know what causes this problem ? where is the micro switch located? what does it look like? is it a big deal to replace? if it isnt too hard a job ,has anyone come across the possibility of a 2nd hand one being fitted?
  14. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    If it is the same as efflicted the Mark IV Golf it is one of two things :
    1. The micrososwitch that confirms that the door is close / open is gunked up with spray lube from when the locks are lubed. (part of the lock mecahnism)
    2. A dry joint on the circuitboard in the lock mechanism.
    On the Golf if it was the drivers door, it has been know for people to lock their keys in the car as they would unlock the car chuck the keys on the seat, and shut the drivers door to get something else, and as the alarm didn't realise that the door had been opened the autolock reactivated, locking the keys in the car.
    You have been warned.
    Paul
  15. QUATTRO_REP
    QUATTRO_REP Diesel Power!
    229
    yep i had this prob now..i squirted loads of WD40 init and i havent had it since...it did seem to occour during hot days tho,,, and as we hanvent really had many of those this year i dont know if its because of that!
  16. buckas
    buckas Member
    749
    yeh, because it thinks the door is ajar, then it doesn't arm the alarm properly, as when you lock it, the red lights or indicators dont flash
    drew
  17. garratt83
    garratt83 Member
    244
    Well thought I would see if I could get the microswitch and clean it today.
    Took the side of the the door off but then was stuck couldn't find anything to clean.
    Anyone point me in the right direction?
