Problems while removing oil sump on 1.8tqs
kenlaw50n Sep 8, 2012
  1. kenlaw50n
    kenlaw50n Member
    39
    After being delayed in work for 3 hours extra today I had to readjust plans to replace the oil pump.
    So thought to my self why not strip it and have it ready for the new pump and rebuiling tomrrow. Should only take a an hour or two to strip it down.
    How wrong was I. Everything come off fine. Except the last bolt. It just happens to be one of the 5mm hex bolts that is situated next to the fly wheel. Slid the hex key in and found that without anything other than turning it with my fingers the head has been rounded off by someone in the past.
    Anyone got any tips on how to get this out without dropping the gearbox?
  2. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    thats the first bolt not the last ;)
  3. adamss24
    adamss24 Well-Known Member
    4,584
    406
    That bolt also have a 10mm head on it so you should be ok getting a long reach extension ...
  4. kenlaw50n
    kenlaw50n Member
    39
    what and hammer it on? outer of the head is round.
  5. Broken Byzan
    13,237
    465
    10mm 1/4 inch wobble bar. It will have both10mm ext and 5mm int hex's unless it's been changed.
  6. aragorn
    18,436
    845
    I just did the sump on my track cars engine a couple weeks ago, and mine were just normal cap head screws like every other sump bolt, no external hex.
    If they're the same as mine and totally rounded, then TBH, your going to have to remove the engine or remove the gearbox, and get at it with mole grips or similar.
    If you want to try something you might find you'll be able to glue the hex bit into the screw and get just enough purchase to crack it off.
  7. Ste_Nova
    1,223
    47
    alloy sump? smash it with a hammer, get to the bolt and remove, buy new sump
  8. Broken Byzan
    13,237
    465
    Hammer a spline bit into the hex then, that should do it
  9. Kingfisher
    Kingfisher Active Member
    277
    49
    is there enough room to weld a nut onto it??
  10. aragorn
    18,436
    845
    Haha, brutal, but might just work!
  11. kenlaw50n
    kenlaw50n Member
    39
    haha would love to see someone get a weld in there. Sorted with some epoxy and a torx bit. quite relaxing lying under a car and just holdoing something in place for 15 mins. lol. Used the two 10mm hex bolts from the old oil pump in they two holes to make it easier if I have to do it again. In final stages of refitting front end then top it up and give a test run.
