Problems starting / Rough idle. > Video Inside <
A1DEYB Aug 24, 2011
  1. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    When the car is both cold and hot it will struggle to start from time to time, when i say struggle i mean i am turning the key for around 6 to 8 seconds (when its playing up at its worst) waiting for it to catch?
    Another thing it seems to be doing also is suffering from erratic idling, the rev counter will bounce between 800rpm and 600rpm with the engine sounding like it's missing.
    Its been serviced around 700 mile ago with PD oil and a new air, oil and fuel filter by a good mechanic i know.
    The car is a 56 plate 2.0L TDI 140, manual with 50K.
    This is the from this morning, as you can see the glow plug light has already gone out and it still struggles to catch and fire.
  2. A1DEYB
    1,682
    43
    You'll notice the video shaking, that's not me, that's the car shaking, the video phone is held against the steering wheel so it's not my hand shaking.
  3. J8Y PW
    J8Y PW Member
    80
    9
    Are you running with a Diesel?
    I've come across this a few times myself even when the car is warm and at a stand still. Not 100% sure of the problem, although I sometimes put the particulate filter to blame. Do you do short burst trips or long miles when using the car?
    My particulate filter needed clearing out a while back and Audi roadside assist came out as the car would not use more than 2,000 revs. We simply turned the engine on, revved to 1,500 and burnt all the **** out of the particulate filter. During the process the car was rumbling/shaking like in the video.
    Don't hold me to this being the cause though. Someone here may be able to give you a better more precise answer.
  4. A1DEYB
    1,682
    43
    Yes, mines a TDI 140 and doesn't have a DPF so i don't think it's the same problem as yours mate.
  5. A1DEYB
    1,682
    43
    What information do i need to provide in order for me to get some suggestions as to what maybe causing the problem.
    Reason why i ask is because I've posted two threads about this issue and nothing has really been suggested.
    Tell me what you guys need and i'll get the information as i need to get this fixed quickly as possible.
    Thanks :thumbsup:
  6. A1DEYB
    1,682
    43
    BUMP!
  7. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    have u tried unplugging air flow meter ?
    sounds like a bad miss fire ?
    check fuel filter ?
    u need to scan with vcds realy
  8. vorney
    vorney Member
    123
    LooKs like a glow plug might of gone down. Or they have a bit of probes wi loom on injectors.
    Or may be an injector not firing right
  9. A1DEYB
    1,682
    43
    Hopefully VCDS will tell me what's wrong tonight.
  10. A1DEYB
    1,682
    43
    If it was an injector it wouldn't drive right though would it, apart from the lumpy idle, the ***** it is to start it drives fine mate.
  11. vorney
    vorney Member
    123
    not all the time i had a polo in garge not so long ago idle missed its tits off reving fine pal lets see how it foes tonight. i now have ways of cleaning injectors out pal :rock:
  12. A1DEYB
    1,682
    43
    We'll see what Gareth's VCDS shows tonight, just out of interest.. How do you clean the injectors out now? I assume you're not on about some Redex type stuff?
  13. tdi-man
    1,783
    64
    injectors realy need to be removed and cleaned to be done proper which aint cheap.
  14. A1DEYB
    1,682
    43
    Have you had this done yourself? How many hours roughly were you charged?
  15. tdi-man
    1,783
    64
    its a few hours labour to take injectors out as they have to be set back up correctly . ive had mine swapped some time ago with newer ones.
    best wait a get it code read
  16. A1DEYB
    1,682
    43
    Won't be getting scanned tonight now as the lad that's doing it for me is busy again.
  17. vorney
    vorney Member
    123
    We need a vag com near by any 1 want to help Bradford area
  18. TimG
    TimG Active Member
    942
    45
    Might be the temp sensor, heard this can cause starting issues + lumpy idle.
  19. A1DEYB
    1,682
    43
    Not scanned with VCDS but another fault finding device (snap on) and no fault codes found?!
  20. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    305
    dont know much about oil burners soz but it sounds like a injector to me
  21. A1DEYB
    1,682
    43
    Due to no faults showing up last night we opened up the fuel filter housing to see if that has dirt in it and also to check the 'O Ring' which seals the unit, it would appear it's letting air into the system as there were air bubbles present in the fuel. The O ring is slightly damaged so I'm getting a new one to rule that out.
  22. A1DEYB
    1,682
    43
    MAF sensor at fault in the end up! Not actually changed it because once the fault codes have been cleared the car has been behaving itself.
    £85.25 for a MAF from Audi is this about right? :confused: This price includes exchanging mine with Audi Leeds?
    I will be buying another one soon but i didn't think they were that expensive.
  23. tdi-man
    1,783
    64
    if i remember rite a Maf fault wont bring up a fault code.
  24. A1DEYB
    1,682
    43
    The first time it was scanned was using my mates snap on code reader, the second time the car was scanned with some proper VAG kit, it said VAS on the handheld computer screen thing the guy used and it showed MAF fault - sporadic?
    Anyway, cleared that fault and the car has been fine since, what i was told though is you can re programme the injectors to fire more fuel in when starting the car and idling to help get rid of rough idle, this is getting done this weekend although the car does seem to be fine now?
  25. tdi-man
    1,783
    64
  26. A1DEYB
    1,682
    43
    Thanks for the link mate but that place is miles away from me!
    The timing belt is due on my motor soon anyway so it will be.
    :thumbsup:
