problems-alarm keeps going off and the interior lights are flashing
pete_moore16 Aug 5, 2009
  1. pete_moore16
    pete_moore16 New Member
    12
    as title really its got me stumped just wondering if its at all a common problem happened bout an hour ago right after i washed the car so ive got a feeling somethings got wet but i have no idea what!
    any help would be much appreciated
    thank you!
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    fusebox?
  3. pete_moore16
    12
    nah all fuses present and correct it was the first thing i checked but ive just been snoping round to see if i could see wot it could be and as the interior light flashes theres a clicking that sounds like a relay anyone had a knackered relay cause a problem like this before?
  4. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Could be boot sensor mate, do a search on this pretty sure I've seen somthing on this
  5. pete_moore16
    12
    well as of now it seems to have fixed itself which makes it very difficult to track the problem and i need to sort it as the car is for sale dont want to sell a car with a problem lol
  6. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    I had this happen on my car a while ago...
    Turned out to be the door pin switch. Mine was passenger side. The interia light flashing was a way of the car telling you that its not right,
    If you lock the car with the problem does the alarm go off? If it does and you have vag com it will tell you which sensor triggered it.
    Also... when it does it... see if the red or white light that are on the doors are flashing, If its a door sensor that door will have the flashing lights to match the interia light.
    To fix this there are 2 routes... one is a new switch but this is expensive as its part of the door lock. the other is ... adjust the door striker slightly so the switch makes full contact or clean the switch with wd40 and make sure its moving freely.
  7. pete_moore16
    12
    paul that makes sense because everynow and again the screen in the instrument cluster says a door is open when its not to sort that for a short time i just have to open the drivers door then close it again so i presume it will be the drivers switch
  8. Broken Byzan
    13,237
    465
    It's the drivers door microswitch, common failiure when its warmer. The problem is the microswitch isn't available on its own so you have to buy a whole door lock mechanism @ £90 ish and then fit that to cure it
  9. Nilz
    11,300
    859
    Do a search on microswitch, theres loads of info on it and quite recently 'dancarpy' did a decent write up on how to resolve this with some pics too :)
