problems adapting a new key with VCDS on 8P
nick9one1 Mar 21, 2013
  1. nick9one1
    nick9one1 Member
    74
    I've got the full VCDS v11 and have followed the guide on rosstech for adapting a new fob (buttons only, not immobiliser).
    [Select]
    [46 - Cent. Conv.]
    [Adaptation - 10]
    Enter channel "01"
    [Read]
    This will display the number of currently stored remotes in "Stored Value".
    VCDS indicates that 1 fob is currently matched to the car
    Enter your total number of keys up to a maximum of 4(including any existing keys) in "New Value"
    I enter '2'
    [Test]
    seems to hang here?
    Verify that the number in "Test Value" is correct.
    test value never updates to '2'
    [Save]
    save button is greyed out, as I presume the test hasnt succeeded .
    Then press and hold (for at least one second) the UNLOCK button on the fob
    Does anyone have any suggestions?
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    erase the keys first then recode
  3. NHN
    29,576
    1,779
    Yeah that's what I do.
  4. nick9one1
    nick9one1 Member
    74
    ok thanks, not sure what happened but the second fob just started working! I logged into VCDS again and it says 2 keys are paired.
    Just need to code in a new immobiliser chip now... I've got as far as getting the SKC with commander, and successfully logging into the Immobiliser [25] Security Access with the pin.
  5. Gilb2406
    Gilb2406 New Member
    I'm having this exact issue too. Car came with 2 keys and the spare works in the door and starts the car etc, but the remote doesn't function.
    VCDS shows 1 key learned and I can't update the value to 2. Scared to erase keys in case any problems occur while programming and I'm stuck with no remotes!
    Can someone 100% confirm that I have to erase the keys first, and if so, how do I do this?
    2005 A3 8P 3d 2.0 FSI
    Thanks in advance :)
  6. NHN
    29,576
    1,779
    You have no choice but to erase & add both keys.
  7. Gilb2406
    Gilb2406 New Member
    Thanks NHN. I did do it in the end. Car blinked to acknowledge both keys but key 2 still doesn't work. Very odd. Think I need to get a new remote on fleabay
  8. Steve220
    Steve220 Member
    234
    15
    I'm having the same problem - a good friend of mine who works with vags says at times, they just die
  9. Gilb2406
    Gilb2406 New Member
    Like everything I suppose!
    Odd how the car recognises it when learning though!
