Problem!!!!!!
Mickeybhoy67 Feb 6, 2008
  1. Mickeybhoy67
    Mickeybhoy67 Member
    45
    My mate has the full version of Vag-com 409.1 but when he's connects it to my car and click option 1 Engine when cannot access the other options.
    Does anyone know this is?
    Cheers in advance
  2. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    When you say cannot access the other options, what do you mean? Does it report the part number etc. of the ECU in the top fields and just the buttons at the bottom (recode, adaptation etc.) don't work; or does it fail to read the part number, work-shop code and soft-coding completely?
    I see from your profile it's an A3, but what year?
    Also, I guess this isn't a genuine Ross Tech interface?
    Regards,
    Rob.
  3. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Yes it finds ecu part no problem, just can't access the buttons at buttom.
    Its A3 Sport 98
    Is an OBD II I bought on ebay
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    You don't get all the features unless you have a licensed version, which I do, and thats about 300 quid
  5. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Cheers but my pal has the full version
  6. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Has anyone got any ideals
    Any help would be much appreciated!!!!
  7. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    I cannot think of a reason for the behavior you describe other than no communications to the controller. Does the "wheely" thing in the upper right corner continue to spin? This sounds like an issue with the interface. There is no reason for VAG-COM to disable the buttons on the screen unless it is not communicating properly.
    Have you tried to "speak" to any other modules?
  8. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Yes the wheely thing spins
  9. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    Try Options -> Start Baud = 9600.
    -Uwe-
