  1. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    just as it was all going ok, i went over one of those small but high speed bumps. went over real slow and came down with a bang. Then it sounded like something was rubbing. looked under for anything hanging off but nothing then i thought it was a wheel rubbing but no. the rubbing sound goes with the cars speed. managed to get it home and jacked it up. got the wheel off and it looks like the drive shaft ( rod going to wheel !) is trashed. there was a bit of rubber hanging off. also the scraping noise happens when i turn the brake disc but sounds like it is coming from just behind the front passenger side wheel. only makes the sound when the disc makes a full rotation. it's like the prop or something has lost loads of oil? going to call ed (APS) in the morning see if they can come pick it up! Not happy!
  2. claudefrog
    claudefrog Member
    372
    sound like you have shattered the cv joint, new driveshaft maybe required
  3. edward_harris
    1,061
    is that big money?!
  4. Jampublic
    Jampublic Taking it easy..
    974
    12
    Sorry to hear Ed, hope its nothing to bad! :(
  5. claudefrog
    claudefrog Member
    372
  6. edward_harris
    1,061
    Thanks mate. Spoken to Aps it's going there Monday. Was quoted £250 to transport it there but wangled it with the AA to do it for free! Apparently Aps have got a few drive shafts anyway do ill let them sort it out!
  7. steebo888
    steebo888 Member
    218
  8. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    You've lowered it right? By how much? How much space is above the arches?
  9. bouncer--daz
    bouncer--daz A dog is for life....not just for friday nights!
    537
    Drive shafts brand new will cost ya below £100 anyway and apparently they are an easy part too replace... mechanic friend of mine said he does them in about 20min so maybe an hour too a first timer? had a look at mine while under the car last. think mines got a slight bit of play on the passenger side. Going to pick up a 2nd had one off a breaker and fit it myself if it gets any worse. Hope you get it sorted though mate
  10. edward_harris
    1,061
    yea it has been lowered but not loads, a pic
  11. danotto
    danotto VAG HUNTER
    1,090
    where are you located im also in reading havent seen this car around before
  12. Dave_Bayern
    1,913
    That looks quite a lot.
    How many fingers can you fit above the wheel before you hit the arch?
    Approx 2 is the maximum you can lower without having driveshaft and sump related problems really.
  13. edward_harris
    1,061
    just checked 2 is a squeeze!
  14. Dave_Bayern
    1,913
    Just move it up a TINY bit once you've had the driveshaft fixed them. I've had mine lowered by that much for over a year and not one single problem so far...
  15. fingermouse
    fingermouse thats me
    4,003
    112
    are you sure you havn`t bent the disc guard and just torn the cv boot ???
    got any pics ???
  16. edward_harris
    1,061
    not 100% sure, but all the rubber is hanging off the drive shaft inner gater. the scraping noise is behind the passanger front wheel not in the arch. and only makes a scraping noise when it does a full rotation!
  17. Jampublic
    974
    12
    Oh Ed has been spotted a good couple times! :)
  18. fingermouse
    4,003
    112
    its possible you have just ripped the boot
  19. edward_harris
    1,061
    Not sure! find out monday!
  20. simch
    simch Active Member
    2,028
    hmmm, I reckon you may have clouted the miltek centre box and its catching the propshaft....? I cannot see a cv joint dying in such a way, (they just go! ).I suppose if you can see damage then maybe it is the joint but the miltek clearance ot the prop can be tight, hence I took mine off and ran the unsilenced centre pipe!
    Good luck Ed, let me knwo when you come pick the beasty up, I'll pop down and say hello if I can!
  21. lUCKYS3
    lUCKYS3 Member
    46
    A little off topic i know, but what percentage tints have you on the imola??
  22. edward_harris
    1,061
    they are light smoke from pentagon glass! it's been droped off to APS today! working on it now! gonna give them a call in a minute! Got the AA to take th car for free! result!
  23. edward_harris
    1,061
    Spoke to Ed, the problem was a cv boot?! going to be replaced in the morning! the scraping was just the prop on a heat shield so no problems there! should be all back together tomorrow!
  24. claudefrog
    claudefrog Member
    372
    ahh not soo bad.. a universal Cv boot only costs around £5 1 hours labour.. job done
  25. edward_harris
    1,061
    good good! they are going to raise the ride hight as well about 10mm all round!
  26. edward_harris
    1,061
