Problem with friends A3
MarkTweedley Mar 6, 2013
  1. MarkTweedley
    MarkTweedley Member
    144
    Hey all, my mate's A3, 2004 140 Diesel, is having a problem with the fans/blowers in the interior.
    Although on the digital display it shows if aircon is on or off via ECON button, it shows how fast/intense you want the blowers but there is no air coming through them. We tried selecting different options and can ear that all vents are opening and closing fine.
    Any suggestions please?
    Thanks guys and gals.
  2. dancupra225
    dancupra225 Active Member
    667
    25
    Mine did this pollen filter under glove box také it out replace it they will work
    MarkTweedley likes this.
  3. MarkTweedley
    MarkTweedley Member
    144
    Brilliant. Thanks. We thought it was weird as aircon was still working so didn't think it would be a rad fan swithch, relay or fuse, just not blowing out the vents.
    Will it be ok to just remove the pollen filter as he won't be able to get a replacement until at the earliest tomorrow.
  4. NHN
    29,551
    1,777
    Can you hear the air/fan noise get louder?
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Mark, if you simply remove the pollen filter, the air will just blow into the footwell, and not through the vents. Best to replace the pollen filter with the one that has the activated carbon. That is the one recommended for vehicles fitted with climate control. Then you can see if there are any other issues with fans/blowers etc. .
  6. dancupra225
    667
    25
    Just také it out and put the lid on to see if that the blowers work then buy your filter job done
    Mine work the second i took the filter out
  7. MarkTweedley
    MarkTweedley Member
    144
    Not really. You can feel the tiniest bit of air coming through the vents but thats it. We tried it doing each individual vent with and without air con on and tried recirculation but still nothing.
    We're going to give the pollen filter a go next as didn't have time this evening.
    Thanks for the advice peeps.
  8. NHN
    29,551
    1,777
    You should clearly here the fan speed rising at least, that in itelf is obvious, if not then that needs replacing.
  9. MarkTweedley
    MarkTweedley Member
    144
    Spoke to him about this and he said it was working fine then the next time he'd start the car it wasn't working but then after a short drive and turning car off, leaving it and coming back to it it worked again then the other day it just stopped altogether.
  10. NHN
    29,551
    1,777
    It needs diagnostically checking, possibly a basic setting done to calibrate the system then see what faults are there, I think fan units fauty tbh if you cant hear it spinning as such, get a log then let us know what it shows.
  11. MarkTweedley
    MarkTweedley Member
    144
    He'll love that... sounds expensive if it is the fan!
    Play time tomorrow to see what we can find but not sure when he'll get it scanned.
    Thanks NHN
  12. MarkTweedley
    MarkTweedley Member
    144
    Well we changed the pollen filter, (dam it was filthy), and unfortunately that did not cure the problem.
    Had a word with a friend, (an ex VW technician), and he said some water may have got on one of the plugs in the bulkhead area.
    Going to have a look on Monday, (well today judging by the time), and will report back with any findings in case it is of any use to anyone who gets the same problem.
  13. NHN
    29,551
    1,777
    Just check if the fan unit above the passenger foot well is spinning, when you turn the climate fan control upto full, it should be very obvious, if it isn't then its the fan unit that needs replacing.
  14. MarkTweedley
    MarkTweedley Member
    144
    Thanks for this. Didn't get chance to look tonight. (Pub was calling). Going to be a wknd job now when I see him next.
  15. radhaz
    radhaz New Member
    29
    Back in the day, the motor brushes had worn out in my 1990 100 quattro. Sounds similar to your issue.
