Problem with central locking, electric mirrors and door iluminations
deian3387 Feb 19, 2013
  1. deian3387
    deian3387 Member
    86
    Hi, i have two fault codes stored in the conv ECU,
    01811 voltage for door controller driver side (j386) faulty
    01812 voltage for door controller pass side faulty
    central locking, electric mirrors and the iluminations for both the front doors don't work.
    Fuses are all O.K.
    Has anyone had an issue like this?
  2. NHN
    29,576
    1,779
    I know its both doors, but check the door hinge rubbers, wires break in there.
    The fact both are down, does make you think its elsewhere, but whats 5 minutes going to hurt you checking.
    Check fuses.
  3. hades-
    9,482
    646
    as above very common
    check the thin wires they can be broke but still look ok give them a tug
  4. deian3387
    deian3387 Member
    86
    Thanks for the replies guys.. checked the driver door harness and found that i had a live missing. Re checked the fuse that fed this wire and found a break in the spade of the fuse and not the fuse wire. so when i looked at the fuse in the first place it looked ok.
    So replaced fuse and everything is ok :)
  5. hades-
    9,482
    646
    glad you got it sorted.
