problem witch speedometr a3 8L
ivanbirioukov Apr 21, 2011
  1. ivanbirioukov
    ivanbirioukov New Member
    hi all, I have a problem with my speedometer 1.9TDI a3 8l, marks an approximate speed and only when he wants, at first thinkthat it was speedometer, byt now i change it. I've noticed that when you floor the accelerator the speedometer is showing signs of marked and sometimes make, but when I let the high speed needle down.And a change the speed sensor that goes in thetransmission.I put an cruise control bat it only lasts 1 or 2 minutes or in some cases last longer then the car starts to stick pulled and removed cruse control. The vag com does not fault, well it gives an incorrect key programing but I think it has nothing to do with the problem.
    to see if you give me some clue where I can begin.
    Greetings.
    some video
  2. Greig300
    Greig300 Member
    257
    Could possibly be a bad earth?
  3. ivanbirioukov
    how i can see it? where is the ground of speedometr?
  4. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    does your fuel gauge give inaccurate readings aswell?
  5. <tuffty/>
    21,140
    3,828
    Are you checking the right modules in VAGCOM to test this? try doing a full scan if you haven't already...
    Whats the flashing dash light? somethings not happy...
  6. ivanbirioukov
    yes witch old speedometr, but since i chenge it it work fine.
  7. ivanbirioukov
    in the vag scan i have only one fail
  8. Greig300
    Greig300 Member
    257
    The main ground for the car not the Instrument cluster....
  9. ivanbirioukov
    up...
  10. ivanbirioukov
    where i can see the ground of instruments cluster?
