problem in gear after chaning cylinder head
aviel131 Apr 29, 2014
  1. aviel131
    aviel131 Member
    104
    hello,
    i changed my cylinder head and connected everything back to its place.
    after i started the car its idle ok and when i shift to any gear and let go the cluth i hear bad grinding noise and the car shakes.
    what can cause this issue and how should i fix it?
  2. shan00ble
    shan00ble Member
    211
    Clutch maybe. Maybe gear linkages if you fidled with anything on the block or gear box. Sorry dude hope you find the problem
  3. aviel131
    aviel131 Member
    104
    i cleaned the oil and water passages in the block with 6bar compressor
    maybe its push sludge to the gearbox oil?
  4. shan00ble
    shan00ble Member
    211
    I doubt it. The gearbox is sealed
  5. shan00ble
    shan00ble Member
    211
    I can only think it must be clutch related. Could be your clutch slave cylinder. Have you checked your break fluid level. If not check it and it is possible to bleed you clutch. There is a bleed nipple on top of the gearbox near the gear linkages. I just dont see how doung your head would effect gearing or clutch did ypu do any other work on the car.
  6. aviel131
    aviel131 Member
    104
    no only cylinder head replacing, i am affraid to brake the gearbox because when i am engage the clutch little bit the car shakes and make bad noise.
  7. shan00ble
    shan00ble Member
    211
    Is it only when you engage the clutch
  8. shan00ble
    shan00ble Member
    211
    Or when you engage the clutch and try to select a gear
  9. aviel131
    aviel131 Member
    104
    when i am engage the clutch after i am in gear.
  10. shan00ble
    shan00ble Member
    211
    It must be clutch related ... I suggest that you take your car to someone with a little more mechanical experience. .. there are many people on this forum with plenty of knowledge its just hard to give advice on a problem when there is something going wrong that is not being explained properly. Sorry man... I have tried.
  11. aviel131
    aviel131 Member
    104
    i fully engaged the clutch in reverse and the car not moving at all!
    what can cause that?
  12. shan00ble
    shan00ble Member
    211
    Thats weird. So the gears are grinding in the forward gears but reverse isnt and its not moving the car at all. That could be pointing toward a gearbox or clutch issue.
  13. aviel131
    aviel131 Member
    104
    if my intake manifold is leaking and my exhaust manifold is not connected it make different?
  14. shan00ble
    shan00ble Member
    211
    Well how is car even running.. and how are you asking questions about your gearbox when you engine hasnt even been put back together in full yet. I suspect you knew something was wrong with your gearbox and thus you were testing it before putting the whole lot together. Otherwise you would have finshed assembling your car and then tested it. Or you are playing yhe fool here on the forum and thats just not cool... anyways good luck.
